front springs?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by tom1987, Aug 24, 2003.
  1. tom1987
    tom1987 Registered Member
    Oct 2, 2002
    29
    Ontario, Canada
    I have an 1987 suburban that I bought a 4inch lift for from a tractor traller depo, but they are shorter then the stock leaf springs by about an inch or two so the shackle is sitting forward on a 45 degree angle, but they is no engine trany or transefer case in it right now so it is not full weighed. So the question is will this be a problem when the suspension moves or not thanx for the help /forums/images/graemlins/thumb.gif /forums/images/graemlins/burb.gif /forums/images/graemlins/thumb.gif
  2. Mastiff
    Mastiff 1/2 ton status Premium Member
    Jul 21, 2002
    2,755
    48
    Tucson, AZ
    Doesn't sound right to me. Are you sure they are the correct part for your truck?
  3. Resurrection_Joe
    Resurrection_Joe 1 ton status
    Jan 9, 2002
    17,372
    Gettysburg, SD
    Beaterchevy on ORC (RIP sniff sniff) had the same problem with custom springs on a bare frame and axles setup, the conclusion was that the weight would casue it to even out to normal or near normal position
    Hope that healps
  4. tom1987
    Oct 2, 2002
    29
    Ontario, Canada
    well thanks for the help, the back springs did the same untill the weght was on them, but not as bad as the front. I think when the engine gets put back in it will be fine thanks again /forums/images/graemlins/thumb.gif
  5. tom1987
    Oct 2, 2002
    29
    Ontario, Canada
    [/ QUOTE ] I called the guy and he said that they are the right springs so I guess they are right, but like Resurrection Joe said they should flaten out when I put the drivetrain back init
  6. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    This is normal with front lift springs. They are shorter to clear the frame on compression. Factory fronts are flat, so they pull away from the frame on compression and droop. Lift springs are arched. The shackle eye moves back on compression. If the shackle were at the normal angle, it would hit the frame when the spring compressed. I don't know why the lift manufacturers don't fix that, but they don't. They all do it the cheapest way and that's by shortening the main leaf...
  7. tom1987
    Oct 2, 2002
    29
    Ontario, Canada
    [/ QUOTE ] I called the guy and he said that they are the right springs so I guess they are right, but like Resurrection Joe said the shackle should stand up stright when I put the drivetrain back in it
  8. tom1987
    Oct 2, 2002
    29
    Ontario, Canada
    [/ QUOTE ] well that make perfect sence thanks for the info /forums/images/graemlins/thumb.gif /forums/images/graemlins/burb.gif /forums/images/graemlins/thumb.gif
  9. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    what they should do is make the springs proper and throw in longer shackles
  10. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    exactly...
  11. patrickcampbell
    patrickcampbell Registered Member
    Sep 11, 2002
    60
    my guess would be that you needed 56" springs and u got 52
  12. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    [/ QUOTE ] <font color="green"> You're thinking of rear springs. </font>
