front suspension k5
Discussion in 'The Garage' started by Justin Fleming, Sep 9, 2005.
  1. Justin Fleming
    Justin Fleming 1/2 ton status Premium Member
    Aug 24, 2005
    767
    4
    Oxford MI
    well the k5 truck I got is equiped with the dual front shocks per side from the factory. It appears someone has replace them not to long ago. I took the truck out for the maiden voyage today and I was getting some harsh clunking in the front. I finally noticed that the shock bolt is the clunking noise. The bolt is tight but it seem they must have not put the hardware together correctly. The bolt is completly tight to the last thread but it appear the bolt is shouldered. I think some spacer is missing or something. The problem is I cant seem to get the bolt out. I dont know if it is cause of the uneven pressure from both shocks or what the deal is.
  2. MattK
    MattK 1/2 ton status
    Jan 12, 2005
    1,713
    Dallas, TX
    probably just frozen in place...spray it down real good with some pb blaster or similar penetrant and let it soak overnight at least.
  3. uglyangelracing
    uglyangelracing 1/2 ton status
    Jun 6, 2005
    271
    Rhode Island
    Maybe the PO cross threaded the bolt and couldnt get it in any farther
  4. WhiteBurb
    WhiteBurb 1/2 ton status
    Mar 10, 2005
    307
    Louisiana
    I had some bad clunking noise in the front that I thought was a shock too. It was the body mount just behind the passenger shackle.
