Front Suspension Options???
Discussion in 'The Garage' started by tsquared275, Mar 22, 2006.
  1. tsquared275
    tsquared275 Registered Member
    Jun 28, 2005
    13
    Plano, Texas
    I have an 84 blazer with stock springs, and the rears are in good shape, but the front springs have about a 2" sag (in another-words, they make more of a "n" shape and not a "u" shape like they're supposed to be, if that makes sense) I was either considering a 2" add-a-leaf, 2" springs, or just replacement stock springs. I need to clear 33" tires, and have a level looking height, not have it look like what a dragster looks like when it launches. Should I just go with a full 2" lift? I am on quite a tight budget. What should I do??? Thanks for any help or advice.
  2. lifted76k5
    lifted76k5 Registered Member
    Nov 27, 2005
    10
    Colorado
    if your springs are stock then thay are sposed to have a negative arch.("n" shape) one of my trucks had a rear overload under the front spring pack when i bought it, raised the front 2in but the ride was ****. i would save and get a 2in lift, replacement springs front and blocks rear will only cost 200.00 or less.
  3. 79k20350
    79k20350 3/4 ton status
    Nov 22, 2004
    7,757
    Ct
    get some 2" springs and a 2" schakle flip for the rear. good ride, the height you want and not too much money, all youll need to add is shocks.
  4. R77K10
    R77K10 Banned
    Mar 15, 2006
    564
    Lincoln IL
    this is the route i want to go with the 77
    you can totally clear the 33" (i assume 12.5" wide) as is if you trim the bottom of the opening of the fenders, thats what i had to do to stop the rubbing on compression turns, with stock springs and everything that is has
    good luck
