front suspension
Discussion in 'The Garage' started by jacked_86chevyk10, Jun 8, 2004.
  1. jacked_86chevyk10
    jacked_86chevyk10 Registered Member
    Feb 4, 2004
    42
    SNELLVILLE, GA
    would it be bad to add like a 2 inch spacer between the frame and the front shackle(or whatever it is called) on the front of the truck and make longer shackles for the rear of the front? (kinda condusing but maybe yall will understand?!?)
  2. big jimmy 91
    big jimmy 91 1/2 ton status
    Feb 21, 2004
    639
    Northwestern Ontario Canada
    I have seen a square tube that spans across the frame rails with the front mounts attached to it for a lift (3"sq. tube ?)
    I'm not sure if it is a good or bad thing though.
    Someone with more knowledge will have to chime in with some answers /forums/images/graemlins/whistling.gif
  3. DBLAZER
    DBLAZER 1/2 ton status
    Apr 2, 2000
    1,716
    Haslet, Tx
    What is it you are trying to acomplish??/ /forums/images/graemlins/dunno.gif
    Seems like a lot of work for adding maybe one inch of lift . I would suggest a body lift.
  4. jacked_86chevyk10
    Feb 4, 2004
    42
    SNELLVILLE, GA
    well i have 4" sus. and 3" body already im tyrin to tweek another 2-3" outta suspension to fir some 38's
  5. smokkey1
    smokkey1 1/2 ton status
    Jan 7, 2004
    2,677
    Los Angeles, CA
    /forums/images/graemlins/hack.gif /forums/images/graemlins/hack.gif will do the job /forums/images/graemlins/waytogo.gif
  6. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    You've got too much lift already. I run 38s on 6". I'm sure it could be done on 4". /forums/images/graemlins/hack.gif 7" is PLENTY!
  7. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    could be done on 4? it better be able to, seeing as I'm sitting on the 40s and 4 /forums/images/graemlins/wink.gif
