front sway bar
Discussion in 'The Garage' started by TXsizeK5, Feb 10, 2003.
  1. TXsizeK5
    TXsizeK5 1/2 ton status
    Aug 26, 2001
    2,518
    College Station, TX
    is it better to take off the front sway bar with a 6" lift , beucase it causes it to bind? Does it have any adverse effects? thanks.
  2. Silver84k5
    Silver84k5 1/2 ton status
    Feb 7, 2002
    3,769
    Hillsboro Oregon
    im runnin 4 inch front springs for total of 5 inches of lift with a 60..... and i dont even notice my sway bar is gone, I used to have 8 inch front springs and its the same story......... Take it off if you notice a difference, dont worry youll get used to :P
  3. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
    Well, the worst case scenario is with a 6" lift, you might have a hard time getting the u-bolt plates lining up the axle and spring pins - just from the basic geometry of it.
    There are a couple of options:
    Sway bar drop kits are available.
    Buying ORD's sway bar disconnects would help out a bit.
    Ditch the sway bar if your springs are stiff enough - there are plenty of people on here running without the swaybar and most don't notice a difference.
  4. TXsizeK5
    Aug 26, 2001
    2,518
    College Station, TX
    I have 6" ez rides, buddy of mine has the same said he ditched the sway bar and no difference besides it rode better.
    Thanks.
  5. OL14BLAZ
    OL14BLAZ 1/2 ton status
    Aug 14, 2002
    1,815
    TEXAS, USA
    Just to repeat what everyone else has told you. I'm running 4" TC springs with Hill shackles on a front Dana 60 without the swaybar and it is no biggie. Just go ahead and ditch it you will get use to the way it leans in corners after awhile /forums/images/graemlins/eek.gif /forums/images/graemlins/grin.gif
    Eric /forums/images/graemlins/usaflag.gif /forums/images/graemlins/k5.gif
  6. BowtieRed
    Dec 31, 2002
    1,776
    Winston-Salem, NC
    flex it out WITH the swaybar and then without, you WILL notice a difference. i have the drop kit if you really want yours, it's a 3" drop, PM me if you want it.
  7. jekbrown
    May 19, 2001
    45,030
    366
    Vancouver, WA, USA
    i got rid of my anti-sway bar about 1.5 years ago. If i was towing a lot or racing my rig I would prolly have figured out a way to use the thing with my lift... since 2 mph is my fav speed... and I don't plan on towing much at all, I've found that I dont really need it.
    j
  8. Swanson52
    Swanson52 1/2 ton status
    Mar 27, 2002
    2,586
    Centennial, CO
    Have to concur with everyone else; I threw mine away with a 4" Superlift, then went to 6" Skyjacker, and still no problems at all. Rides better without. And, of course, I can still roll straight over the curbs at Wal-Mart, no stinkin swaybar holdin me back! /forums/images/graemlins/truck.gif
