Front swaybar Q......
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by fad2blk99, Aug 28, 2003.
  1. fad2blk99
    fad2blk99 1/2 ton status
    Feb 19, 2001
    860
    Charleston, SC
    I got 6" BDS springs, 1" zero-rate add-a-leaves off-setting the front axle the full 1.5" forward, and ORD sway bar QD's. With that set-up, my sway bar pushes the sway bar QD mount rearward about 30 degrees. Will my sway bar still function properly in this position? I know a lot of y'all don't run the sway bar, but I'd kinda like to keep mine for now.....
  2. Jonny-K5
    Jonny-K5 1/2 ton status
    May 27, 2003
    1,654
    SoCal
    it should be fine. you have the ORD piece right? it is a "correct"/disconnect. as long as it hooks up it'll work.
