Front tire wobble?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by chevyfumes, May 25, 2001.
  1. chevyfumes
    chevyfumes Court jester
    Feb 24, 2000
    38,584
    266
    Watch for the muzzleflash!
    At slow speeds when I have the wheel turned all the way the front tires wobble . I have 33's and The axles are stock. Any ideas, besides aliens or possessed vehicle theories?[​IMG]
    <font color=blue> I'd rather have a bottle in front of me, than a frontal lobotomy!
  2. muddin4fun
    muddin4fun 3/4 ton status
    Feb 19, 2001
    5,644
    N Texas
    I would check your front end (tie rods etc) for wear. Also make sure your lugnuts are tight (I know it sounds stupid, but ya never know).
    <font color=orange>hAS ANYONE SEEN MY cAPSLOCK KEY?</font color=orange>
    <A target="_blank" HREF=http://k5chevyblazer.homestead.com/home.html>http://k5chevyblazer.homestead.com/home.html</A>
  3. chevyfumes
    Feb 24, 2000
    38,584
    266
    Its not the lugs![​IMG], I'm just not sure what kind of wear I'm looking for, its only when the wheels are turned all the way, and I also replaced the wheel bearings, and it still does it, so tie rods , anything else I should be looking for...
  4. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    Maybe your wheel or axle shaft is bent, that wouldn't expalin why it only does it while turning though......
    90K5
  5. BlueBlazer
    BlueBlazer 1/2 ton status
    Feb 15, 2001
    1,940
    Is it possible the inside of your tire is hittin the tie rod end or something else. Start up the truck and have someone turn the wheel lock to lock and look to see if its hittin anything. If its a mud tire its most likely the lugs (on the tire) hittin something. When I bought my truck it had no lift and 33" Thornbirds and the lugs would hit the tie rod end and the steering wheel would shake and make a pretty good racket. If thats not it might be something in the steering system or suspension.
    '82 K5 6.2 Diesel, sm 465 np 205, 35" muds
