Front tires rubbing?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Rolled, Nov 5, 2002.
  1. Rolled
    Rolled 1/2 ton status
    Jun 16, 2002
    683
    Anchorage, Alaska
    I just got my rig on the road the other day and today when I was backing in my driveway I heard some loud rubbing. I believe it was the front tires when I turned sharp in the driveway.
    4 inch lift
    35 inch tires
    87 K5
    Question:
    Does my tire lift configuration keep me from turning my wheels all the way in one direction? If so, is there anything I can do except remind myself to not turn sharp? I assume the factory turning stops don't work since the tires are bigger.
  2. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> Trim the corners of the fenders and turn as far as you want. /forums/images/graemlins/thumb.gif </font color>
  3. laketex
    laketex 3/4 ton status
    6,220
    North Texas
    You need more lift. Your body should totally clear your tires. 10" suspension should be fine. /forums/images/graemlins/laugh.gif
    J/K....yeah trim up your fenders, all the cool kids are doing it.
  4. Rolled
    Jun 16, 2002
    683
    Anchorage, Alaska
    I read a couple times that 35's required no mods an a 4 inch lift.
    My driveway has a good size dip and it made the noise when I hit it. I thought it was the fender wells not the fenders???
    10 inch lift? My kids already need a rope ladder to get in /forums/images/graemlins/grin.gif
  5. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    right. to fit into the wells, no mods, to actually move and be effective, minor trimming
  6. OFFRDK5
    Oct 2, 2000
    1,881
    Central IL
    Grab the sawzall. Remove part of fender.
  7. Rolled
    Jun 16, 2002
    683
    Anchorage, Alaska
    Thanks guys
  8. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    Actually if you want to, the factory stops can be adjusted.
    I just adjusted mine so that the tires don't hit the springs at full lock on my Full size Jeep.
    Luckily on My K5 I didn't need to.
    Both have 35".
  9. Rolled
    Jun 16, 2002
    683
    Anchorage, Alaska
    imiceman44 - I'll give that a try beore I break out the reciprocating (sp?) saw.
  10. Greg72
    Mar 5, 2001
    15,680
    1,391
    642 Days to BB2018
    the dip in the driveway is the giveaway...
    You won't be able to see the interference points with the truck parked, except maybe to see "clean spots" on the inner fenderwell areas where the tire is hitting under compression with the tire turned.
    I've done some trimming on mine, but I know that over a big bump on a turn, things will still rub.
  11. Wraparound
    Wraparound Registered Member
    Feb 23, 2000
    91
    Sacramento
    My 33's rub on my stock in the fenderwell, but only when I hit a bump fast while turning hard.
  12. Rolled
    Jun 16, 2002
    683
    Anchorage, Alaska
    Turns out the driver side tire is rubbing the front drag link at extreme right turn.
    I have not looked if I can just adjust the stop yet. Anybody have this problem?
  13. BigBluOx
    BigBluOx 1/2 ton status
    Aug 30, 2001
    301
    Auburn, WA, USA
    I have the same problem, but I haven't fixed it. The previous owner (or maybe the factory) welded my stops /forums/images/graemlins/confused.gif. The next best alternative is crossover steering /forums/images/graemlins/thumb.gif
    Jon /forums/images/graemlins/burb.gif
  14. Rolled
    Jun 16, 2002
    683
    Anchorage, Alaska
    BigBluOx - If mine are welded I'll just weld an extension on to it /forums/images/graemlins/grin.gif
  15. BLUESMAN
    BLUESMAN 1/2 ton status
    Oct 3, 2001
    951
    Phoenix(but it\'s a dry heat...like an oven!)AZ.
    Trey,If you want come on over and I'll trim up the bottom of the front fenders for you.Don't worry I won't cut as much as I did mine!It's prob those 10" wide rims.A small cut and maybe some stronger extended front shackles would prob solve the problem.I'll check on the top for you.Did you get rid of the SM465?I'm off Saturday,if your'e free.Bring the Beer!!Mike
  16. Rolled
    Jun 16, 2002
    683
    Anchorage, Alaska
    Still got the 465 Mike. I'm looking to swap it for the 400 in about a month. Has your brother changed his mind yet? I'll have to do some thinking before I cut up my new mint fenders though.
    Let me know about that top. I'm going to squirt the truck as early as next week.
