Front to Back Gear Ratio's
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Mingler, Nov 2, 2001.
  1. Mingler
    Mingler Registered Member
    Nov 2, 2001
    29
    Calgary, Alberta
    Front to Back Gear Ratio\'s
    I've been told that the gear ratio in the rear of the truck should match the gear ratio in the front of the truck. Is there any truth to this OR is it possible to run 4:10's in the front and 3:83's in the rear??
    Hoping someone will know.
    Thanks in advance
  2. KRAZIE87K5
    KRAZIE87K5 1/2 ton status
    Feb 23, 2001
    3,369
    Chicago, IL
    Re: Front to Back Gear Ratio\'s
    Sure its POSSIBLE, that is if you don't mind breaking your transfer case into tiny little pieces!!! [​IMG] YES, you must have matching gear ratios.
    <font color=red>GOT MUD???</font color=red>
    My license plate reads:<font color=blue> 8 YR SUV</font color=blue>
    <a target="_blank" href=http://24.10.209.54/bigolk5.htm>http://24.10.209.54/bigolk5.htm</a>
    454/TH400/NP205 - 14BFF/D60/w/ 4.10s
  3. Stoopalini
    Stoopalini 1/2 ton status
    Oct 17, 2000
    999
    Austin, Texas
    The gear ratio needs to be the same in front and back or else you will bind up the drivetrain and eventually break something.
    The only difference you could get away with, would be a 1% varience.
    Ex) 4.10 in the rear, and the front could be anything from 4.059 to 4.141
    Thomas.
    -- '84 1-Ton Blazer --
    When the goin' gets tough,
    the tough go 1-Ton [​IMG]
  4. 1Blazin71
    1Blazin71 1/2 ton status
    Aug 23, 2000
    112
    Los Angeles
    Conventional thinking is that the gears must match. But there are those that say that as long as you stay within 1%-2% difference you'll be fine.
    In your case 4.10 / 3.88 = 1.07% so it should work.
    Check out this article on the Randy's Ring and Pinion site:
    <a target="_blank" href=http://www.ring-pinion.com/gear/g0398.html>http://www.ring-pinion.com/gear/g0398.html</a>
    Matthew Meyer
    matthewm@inhollywood.com
    '71 Ochre K5 - 4" Lift 35"s
    ZZ4 350 - 700R
  5. Mingler
    Nov 2, 2001
    29
    Calgary, Alberta
    Thanks a Ton Guys.
    I guess i'm buying TWO lockers :)
    Cheers.
  6. 1Blazin71
    Aug 23, 2000
    112
    Los Angeles
    oops...I read the math wrong in the Randy's article..
    Your 4.10 / 3.88 would be almost 7% difference...not good.
    Matthew Meyer
    ZZ4 350 - 700R
  7. SlyDog
    SlyDog 1/2 ton status
    Oct 23, 2000
    3,035
    Scottsdale, Arizona
    Yea NOT GOOD [​IMG]
    <font color=green>[​IMG]1977 K5 GETTIN IT AWN[​IMG]</font color=green>
    GO BUSH
  8. michaelm
    michaelm 1/2 ton status
    Feb 2, 2001
    872
    mud boggers run wildly different ratios front to rear
    what is the application you are refering to
    Quagmire is one example of the need to run differing gear ratios, he runs ?40s? up front and HUGE out back and did the math to get the final drive to the ground to be equal
    for the rest of us they must be the same
  9. 2cocky
    2cocky Registered Member
    Oct 7, 2001
    59
    Southern Maryland
    Some mud boggers set up their tucks so that the front diff is numericly lower this getts the front spinning faster then the rear they do it in hopes of getting the front to "float" over the mud, sence they run in the mud there is lots of slipage at the tires so they don't break the t-case. But for everyone else that 'wheels you would want to have matching front and rears.
    OOOPS....I THINK I JUST RAN OVER YOUR JEEP THING!!!!!
  10. gator1959
    gator1959 Registered Member
    Nov 4, 2001
    36
    I have a Dana44 front w/factory 4.09 and the 14 bolt rear is 4.10/4.11 that is the farthest apart you can safely get if the truck drives on the interstate.
    '79 K-5,D-44HD(8-bolt),14 bolt(FF),4.09 ratio,427 rat,auto,38" rubber,currently taking body off frame
  11. Leadfoot
    Nov 28, 2000
    3,112
    Western Massachusetts
    Keep in mind, it is final gear ratio that must be within 1% or so. You can have different gear ratio's front to back as long as the tire diameters make the final ratio within 1% front to back. Generally speaking most of us run the same size tires (don't have to carry as many spares), so we need to have ring and pinion ratios that are within ~1% of each other. Abnormal tire wear, different brand or size tires, etc can also factor into the equation as well.
    General rule for street guys, run same brand/size tires and keep the R&amp;P ratios within 1%. Hope this helps.
    See my rig at <a target="_blank" href=http://coloradok5.com/gallery/Leadfoot>http://coloradok5.com/gallery/Leadfoot</a>
