Front trany seal replacement
Discussion in 'The Garage' started by eshorvath, Sep 12, 2005.
  1. eshorvath
    eshorvath 1/2 ton status
    Jun 20, 2002
    373
    Southern Oregon
    I am getting ready to pull my transfer case to replace the adapter. There is a leak from the front for the transmission, not sure if it is from the input shaft seal or the round access hole on the front
    (what is that hole called, has screws to access it,
    is there a gasket behind it?)
    Is there any other spots that can be leaking there?
    How hard is it to replace the front seal?
    Where can i get these seals and gaskets the cheapest?
    I do nto want to have to pull the trans and transfer case, but since I am having to do half, Id like to fix that leak too, while im there, I am away from a parts store by 50 miles, and want to have everything here, ready do go, pull everything, replace and seal everything, and throw it back together the same time.
    Oh, and the gaskets between the TC and trans, do they need to have gaskets, or silicon or both?
    Eddie
  2. dyeager535
    26,979
    Only two seals I recall in the converter area are the hub seal for the converter, and the pump to case gasket. Without the right tools, I doubt you'll be getting the pump off with it still in the air/in the truck.
    Make sure to lube the hub seal before install. Hub seal should be cheap pretty much anywhere.
  3. eshorvath
    Jun 20, 2002
    373
    Southern Oregon
    Does anyone know if this front shaft seal on the SM465 is a quick, easy replacement once the tranny is off?
    What is the access on the front, below the input shaft, that you can see with sheet metal screws? Is that a gasket, should you use silicon to seal it?
    Eddie
