front u-joint removal, help!
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by coolhandluke, Aug 3, 2003.
  1. coolhandluke
    coolhandluke 1/2 ton status
    Oct 23, 2001
    116
    Dallas Texas
    ok, I'm having to replace the front drivers side u-joint, I have the 3/4 ton axle. Removed the hub, removed the rotor, and cannot for the life of me get the spindle off. Is this just time for the BFH, or is there something I'm missing here?
  2. Confedneck
    Confedneck 3/4 ton status
    Nov 1, 2002
    5,236
    Lehigh Acres, Florida
    half ten bolt half d60??
    did you take off the six nuts that hold the spindle on?
  3. coolhandluke
    Oct 23, 2001
    116
    Dallas Texas
    ok, I'ts embarrasing when you don't even know what the hell you have.....
    yeah, I took the 6 bolts off, but after wailing on it, it is still in there, I guess that means I just need to keep pounding
  4. Confedneck
    Nov 1, 2002
    5,236
    the spindle i pulled off a 10 bolt came off fairly easily, try prying it off with a screwdriver...
  5. coolhandluke
    Oct 23, 2001
    116
    Dallas Texas
    ive tried a screwdriver, pry bar, BFH, etc, all to no avail. my ten bolt came apart easily, I don't know what's up with this.
  6. MTBLAZER89
    MTBLAZER89 3/4 ton status GMOTM Winner
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    just make sure when you are hammering away...that you have a 2x4 on the spindle, or use a rubber mallet. Dont hit the spindle with a metal hammer. Like confed said try a screwdriver and pry a little...or hit it with some PB Blaster wait a few then go beat on it some more.
  7. coolhandluke
    Oct 23, 2001
    116
    Dallas Texas
    all right, I figured I just needed to hit it some more, but got tired of swinging. gonna go get some pb blaster, and a new 2x4 after killing the first one. thanks guys.
  8. rampage
    rampage 1/2 ton status
    Mar 20, 2001
    2,261
    74
    Humboldt/Pacifica, CA
    It should come off by beating on it with a hammer like was mentioned, just work all the way around it. If that still doesn't get it then you may try putting a jack under the end of the spindle (with a 2x4 protecting the spindle) and try breaking it loose that way. When you reassemble it put a thin coat of antiseize on the back side of the spindle so it will come off easier next time.
  9. Confedneck
    Nov 1, 2002
    5,236
    its been a while..but try tapping on the very inside lip of the spindle where its about 3/8" thick where the bolts go through, a few good raps should loosen that up pretty well..keep us posted..
  10. coolhandluke
    Oct 23, 2001
    116
    Dallas Texas
    gonna go whip out the jack guys, great idea thanks.
  11. Aquaman
    Aquaman 1/2 ton status
    Apr 21, 2002
    337
    Kansas City, MO
    if you have air tools, an air chizzle will work.......
  12. rampage
    Mar 20, 2001
    2,261
    74
    Did you get it off yet? /forums/images/graemlins/ears.gif
  13. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    brutal job to do
    once you put it back together with antisieze it will come apart next time will no issues
    once you get it to rock a bit jam a screwdriver in the gap and pound the other way using the screwdriver as a leverage point
  14. Mastiff
    Mastiff 1/2 ton status Premium Member
    Jul 21, 2002
    2,755
    48
    Tucson, AZ
    Not to threadjack here, but how bad a job is front U-joint replacement overall? Should I attempt it on my 10-bolt? My symptom is groaning under load in 4-wheel drive (the truck, not me /forums/images/graemlins/rotfl.gif), which I think points at the U-joints?
  15. Confedneck
    Nov 1, 2002
    5,236
    see his other post..he got it..
