Front u joint
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by bigchief427, Jul 17, 2004.
  1. bigchief427
    bigchief427 Registered Member
    Dec 7, 2003
    35
    martinsville indiana usa
    I need the part number (preferably auto zone) the front joint at the axle has inner snap rings and i can't find on one that doesn't have external snap rings
  2. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    The front joint at the front axle will not have internal snap rings.
  3. az-k5
    az-k5 1/2 ton status
    Oct 15, 2003
    2,774
    Phoenix AZ
    Are you referring to the axle shaft or the drive shaft? No drive shaft joint for the front yoke end has internal rings, at least from what I have seen.
  4. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Nope, they all use a Spicer 1310 from the factory, part number 1-0153 in Neapco. (external rings)
  5. bigchief427
    Dec 7, 2003
    35
    Well who knows what front driveshaft is in it. IT IS a 81 k10 pickup i have put a dodge dana 60 and a 14bltff. the front driveshaft does not have rings for the external snaprings i thought that they were just missing put then i found the inner snaprings. ok so all the "right" joints per napa the zone, advanced and post yer part # are all wrong the cross is to big to fit in the end of the shaft. And the caps are to big to fit in the holes. hmmm i found a joint laying around for my rear shaft and the cross and the caps are a perfect fit BUT external rings hmm hard tellin were the shaft came from BUT that what is in the truck and yes it is on an auto trick with a cv at the t-case
  6. bigchief427
    Dec 7, 2003
    35
    [/ QUOTE ] Stock Saginaw S44, internal clips, 2-3011 Fits front saginaw style CV and rear driveshafts on 10 bolt equipped rigs with auto trannies
  7. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    REAR driveshafts, yes.
    ALL front pinion joints on our trucks are spicer 1310s, not saginaw.
  8. ugly_blazer
    ugly_blazer 1/2 ton status
    Apr 12, 2004
    1,214
    dodge dana 60 /forums/images/graemlins/deal.gif
    Would this make a difference? The Dodge's used internal snap rings...
  9. bigchief427
    Dec 7, 2003
    35
    dude i pulled that qoute from the post yer part# that you posted. Ok so i need a 1310 with inner rings i guess . and the dodge dana 60 seems to match up fine i bought a new yoke for it from and randys ring and pinion
  10. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    There is no such thing as a 1310 with inside clips unless it is a wheel joint.
    Spicer style u joints use external locking clips.
    I'd double check your driveshaft.
    Dodge Dana 60 will use a 1310 or 1330, no matter what, your pinion joint should use external locking clips.
  11. bigchief427
    Dec 7, 2003
    35
    i think i've figured out how to make it work for a while till i upgrade to 1350 or so I will take a pic soon to show that this is what is on the truck it beats the holy hell out of me what it is
  12. ford_assassin
    ford_assassin 1/2 ton status
    Nov 8, 2003
    101
    Bakersfield, Ca.
    1-0174
    Its lists as a 1310 too, what is the difference?
    Thanks!!
