Front vent window removal/install....help
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Bone85K5, Mar 7, 2003.
  1. Bone85K5
    Bone85K5 1/2 ton status
    May 7, 2000
    436
    Columbus, Georgia
    I need to replace my pas. vent window. Am I correct to assume..
    1. Remove door panel
    2. Take out 3 screws that hold entire window frame in.
    3 Install reversal or removal??
    Anyone have anthing to add please speak up.
  2. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    there is also 1 or 2 bolts hold the vent window in underneth the door panel, but other than that, yes you are good.
  3. tecton
    tecton 1/2 ton status
    Dec 1, 2002
    1,553
    WV
    i need to replace mine completely...let me know how all this goes
  4. 70~K5
    70~K5 1/2 ton status
    Apr 13, 2002
    2,032
    sillycon valley
    Don't forget the screws that come from the front and top into the vent frame.
  5. jakeslim
    jakeslim 1/2 ton status
    Sep 18, 2002
    2,686
    Napa, CA
    good luck trying to line up the screw holes up top. I bought a new vent window and it was tough! If your buying used, you should be ok
  6. Rolled
    Rolled 1/2 ton status
    Jun 16, 2002
    683
    Anchorage, Alaska
    They are a real bitch to get out. It helps to pull the window seals to create more room. You will need to twist it a bit while pulling out of the top. It has a funny right angled piece at the bottom of the frame.
    If you have tinted windows I would be very patient so you don't scratch them up.
  7. Bone85K5
    May 7, 2000
    436
    Columbus, Georgia
    Well....thought I had a set from our 90 parts suburban, but no luck..found the one ie needed in a junk yard...for $8...guy said it was form a 82....when i got home and compared it was a pre 79..so im now out $8 + $10 (got it tinted b4 i tried to fit it) anyone need a pre'79 vent window???
