Front wheel bearing grease??
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 88K5Jimmy, Nov 14, 2001.
  1. 88K5Jimmy
    88K5Jimmy 1/2 ton status
    Jan 10, 2001
    1,323
    Tulsa OK
    what is the best or adequate grease to use in the front wheel bearings? Also, what should I watch for in repacking them? Any suggestions, hints, tips?
  2. jimmyjack
    jimmyjack 1/2 ton status
    May 11, 2000
    2,290
    Tucson Az
    You definately want to use a hi temp grease. It'll say hi temp on the can itself. If you're not sure just ask the parts person. I usually just throw a dallop in a plastic baggy and work it in really good( with a new, out of the box bearing )
    That jeep thing? Yah I understand it....... Like my Blazer? <a target="_blank" href=http://community.webshots.com/user/blazerk5>http://community.webshots.com/user/blazerk5</a>
    Jim
  3. rampage
    rampage 1/2 ton status
    Mar 20, 2001
    2,261
    73
    Humboldt/Pacifica, CA
    The best thing I found is a wheel bearing packer (I think that's what it's called). It fits onto the end of a grease gun and forces the grease throughout the bearing and costs probably $10.
  4. AussieK5
    AussieK5 1/2 ton status
    Jun 17, 2001
    316
    A land girt by sea
    I use the super doper waterproof stuff that you use on boat trailers etc.
  5. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Marine grease is the hot ticket if you play in the mud/water. It's the green stuff that doesn't break down when it mixes with water. Automotive grease turns into sludge if a little water gets into it.
