front wheel bearings *FIXED*
Discussion in '1983-2005 S-Series models' started by COCHEV, Mar 11, 2004.
  1. COCHEV
    COCHEV 1/2 ton status
    Jul 9, 2002
    4,055
    Washougal WA
    my nephew has a 83 s-10 blazer and his front bearings are trashed on the drivers side. how big of a pain are these to do on the ifs stuff? napa wants $200+ for what they call a whole new "front assembly" my nephew is poor so we are thinking of hitting the junkyard saturday. any info on this would be great. thanks,
    jason
  2. Confedneck
    Confedneck 3/4 ton status
    Nov 1, 2002
    5,236
    Lehigh Acres, Florida
    Re: front wheel bearings
    never having worked on one myself.. but looking at our 99.. im imagining that 200 bucks is for a knuckle that includes pressed in sealed for life nonchangeable bearings..
  3. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    Is it 2wd or 4wd? My 2wd stuff for my 87 was cheep. I would think you could replace all the bearings, seals, calipers, pads, brak lines, and maybe some other stuff for $200. If the spindles are toast I have a set with good bearings, new but now rusted rotors, new pads, etc...sitting in my driveway. I just took the whole spindle off and converted to 12" brakes /forums/images/graemlins/bow.gif /forums/images/graemlins/peace.gif
  4. COCHEV
    Jul 9, 2002
    4,055
    Washougal WA
    its 4x4. no spindle, have to buy a new hub assembly. the bearings are pressed into the knuckles and the cv runs through that. damm ifs anyways! /forums/images/graemlins/rotfl.gif /forums/images/graemlins/thumb.gif
    looks like i know what i'm doing this weekend. /forums/images/graemlins/doah.gif
  5. COCHEV
    Jul 9, 2002
    4,055
    Washougal WA
    New hub assembley from the junk yard for 35 bucks. take off the tire, caliper, rotor. remove the lock nut and large (1 5/16") nut behind it, then remove the three bolts that hold the hub assem. in. remove and replace. walla! fixed. if anyone cares /forums/images/graemlins/grin.gif
  6. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Sweet! That's WAY cheaper. /forums/images/graemlins/thumb.gif
  7. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    They fit right up until they switched to the dual-piston caliper (97-98 or so) even if it has ABS - so there's lots in the junkyard to choose from /forums/images/graemlins/wink.gif
