Front Wheel Bearings?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 89OKIE, Oct 22, 2001.
  1. 89OKIE
    89OKIE Registered Member
    Aug 16, 2001
    11
    How and what special tools are needed to change the front wheel bearings on an 89' with man. locking hubs.
  2. ArrowheadK5
    ArrowheadK5 1/2 ton status
    Aug 3, 2001
    252
    Northern MN
    Same question, but for 87? any difference?
    My spindle nut(s?) backed off and wrecked my hub and outer bearing. Interested to know what responses you get.
    Good Luck! [​IMG]
    Four wheel drive, four wheel expenses...
  3. SCOOBYDANNN
    SCOOBYDANNN 1/2 ton status
    Sep 4, 2001
    2,129
    21
    El Paso, TEXAS
    snap ring pliers make it easier but you dont need them, i use 2 small screwdrivers, the hub socket tool, which you can buy from pep girls or autozone, its the same for all 1/2 fronts, about $10 make sure when you put it all back togather you get that little nipple on the first ring to firlmy get into a hole, if it dosnt later on its a PIA.
    Sun Desert Offroad <a target="_blank" href=http://4x4.alloffroad.com>4x4.alloffroad.com</a>
  4. rampage
    rampage 1/2 ton status
    Mar 20, 2001
    2,260
    72
    Humboldt/Pacifica, CA
    Just did mine this weekend. Along with the other suggestions, it will also help to have a bearing packing tool. This is the easiest way I know of to get the grease inside the bearings. I think it's less than $10 at any auto parts store. Of course you need a grease gun to go with that. If you don't have a hex wrench to remove the brake calipers then pick one of those up too, I forget what size it is though. Make sure to seat the bearings correctly and torque the adjusting nuts correctly. This will require a torque wrench also, one that reads up to 200 ft/lbs will do. I'm sure you could get by with the good-n-tight method, but since I don't like my wheels falling off I'll just stick with the specified ratings [​IMG]. If you haven't done this before then a Haynes manual would be helpful.
