front wheels locking up
Discussion in 'The Garage' started by jackedk5, Aug 6, 2003.
  1. jackedk5
    jackedk5 Newbie
    Aug 6, 2003
    I recently bought an '88 k5 w/blazer. When I put it into four wheel hi and drive on pavement the front tires seem like their locking up. I drive it on dirt/grass and it seems fine. Is this normal for an older 4x4. Ive heard that it is and isnt but am looking for a larger response than my dad and my buddies...thx
  2. Confedneck
    Confedneck 3/4 ton status
    Nov 1, 2002
    5,236
    Lehigh Acres, Florida
    4 hi on dry pavement with the hubs locked? or are they auto hubs..if its binding up you could have different gears front and rear..but id imagine that driving in 4hi with the hubs locked on pavement could be a pretty good drag...
  3. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
    First of all, welcome to CK5.
    Second of all, it is not recommended to drive on dry pavement in four wheel drive. In a straight line, you should be okay, but when you start to turn you'll experience driveline bind and the wheels will chirp a bit because they want to travel at different speeds.
    When do you experience this "locking up?" Only on turns? If it's really bad even in a straight line, you may want to check and make sure the axle ratio is the same front and back before you screw up your t-case! /forums/images/graemlins/eek.gif
  4. khotmer
    khotmer 1/2 ton status
    Oct 23, 2002
    228
    columbus, oh
    depends on how bad it really is ...it may be mis-matched gears if it hops and carries on but if it just making binding noise when turing and such it is probly okay.. my .02
  5. CHEVY 4WD
    CHEVY 4WD 1/2 ton status
    May 14, 2002
    1,773
    Florida
    shoulds like differnt gears to me too... you said its a 88 does it have a 10bolt front and rear?
  6. Twiz
    Twiz 1/2 ton status
    Mar 8, 2001
    3,729
    Clearfield Ut.
    Operating to designed intent.
    Normal for all true 4wds when locked (IE, not AWD)
  7. mastercraftkpk
    mastercraftkpk 1/2 ton status
    Mar 12, 2003
    192
    Houston, TX
    It is normal for ANY real 4X4. It is just more noticeable on your truck because it isn't a tiny, light weight, short wheel base jeep. Keep it out of 4wd on the pavement unless you want to replace tires and other components sooner rather than later.
    /forums/images/graemlins/usaflag.gif /forums/images/graemlins/k5.gif
