Front window seals frrom JC Whitney??
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 87GMCJimmy, Oct 25, 2002.
  1. 87GMCJimmy
    87GMCJimmy 1/2 ton status
    Nov 21, 2001
    582
    Phoenix, AZ
    I replaced the drivers front window seal and now the window will not go up without major help. It's not lining up with in the seal correctly. I'm pretty sure that I screwed up something putting it in. Has anybody used seals from JC W. with success or it this part of the problem. Are the seal from LMC better? Maybe I'll check GM part direct for prices?
    Mike
    PS. Does anybody know the gm part numbers for the window channels?
  2. 95 Silverado
    95 Silverado 1/2 ton status
    Nov 9, 2001
    467
    Central PA
    I had the same problem on my last truck, I found that the old original seal seemed to fit back inside the channel, the edges weren't visible when installed, the replacements from JC Whitney when installed the same way squeeze the window and make it hard to go up and down. I found the outer lip of the replacement seal fits at the edge of the window channel and the window is much easier to operate.
  3. Tweetysuarus
    Tweetysuarus 1/2 ton status
    May 25, 2002
    2,294
    Lynnhood,WA
    LMC were better for me I tried JC Whitney and had the same problem!
    Bill
  4. FWP
    FWP CRS
    Oct 11, 2000
    3,845
    3
    Prescott Valley, AZ
    Been there, done that...Put one side JC crappy, and the other GM on my pickup---world of difference /forums/images/graemlins/crazy.gifGo factory on that stuff, if you can. Well worth the extra bucks IMHO.....
  5. wrathORC
    wrathORC 1/2 ton status
    Apr 27, 2002
    908
    Hancock, MI
    It's probably the inside seal that's stopping it from going up and down. It can be bent.
    If it's not, find out which seal it is. More than likely it is the one on the inside that rubs on the window.
