front yoke nut on a 203 is it reverse threads???????
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by chevyfumes, Aug 2, 2002.
  1. chevyfumes
    chevyfumes Court jester
    Feb 24, 2000
    38,584
    266
    Watch for the muzzleflash!
    is the front yoke nut on a 203 reverse threads,?????Because i have a 3/4" /forums/images/icons/mad.gif breaker bar on that bad boy and it wont budge.....
  2. chevyfumes
    Feb 24, 2000
    38,584
    266
    WTF, I tried both ways w/ a 2' 3/4" breaker bar and it wont budge I even hit it with a torch... NOTHING AAAAAAHHHHHHHHH!!!!! /forums/images/icons/crazy.gif /forums/images/icons/crazy.gif /forums/images/icons/crazy.gif
  3. thatK30guy
    Jan 12, 2001
    32,076
    55
    No, no reverse threads. Just one tight mother of a nut!! /forums/images/icons/wink.gif
    Try using an impact gun, I mean a GOOD impact gun. /forums/images/icons/wink.gif
  4. mike reeh
    mike reeh 1/2 ton status
    Jul 23, 2001
    752
    San Diego, CA
    its definately not reverse threads. remove both driveshafts, put the longest breaker bar you have on the nut, put the trans in 4lo, start the engine and put it in reverse*. with the breaker bar hitting the ground, something is going to give, hopefully the nut!
    * proceed with caution!
  5. chevyfumes
    Feb 24, 2000
    38,584
    266
    /forums/images/icons/shocked.gif /forums/images/icons/shocked.gif /forums/images/icons/shocked.gif I'd love to be a fly on the wall of your garage to watch your mechanical mishaps..... /forums/images/icons/grin.gif /forums/images/icons/grin.gif /forums/images/icons/wink.gif
  6. thatK30guy
    Jan 12, 2001
    32,076
    55
    LMAO!! /forums/images/icons/laugh.gif You mean, the nut holding the breaker bar? /forums/images/icons/laugh.gif /forums/images/icons/grin.gif
  7. wrathORC
    wrathORC 1/2 ton status
    Apr 27, 2002
    908
    Hancock, MI
    that cracks me up. if it was me, not only my POS snap-on ratchet would break but when it let loose it'd take out an exhaust or various other parts.
    You need to put a close circuit camera in your garage and record yourself. I bet you'd get enough material to earn an award in no time.
  8. mike reeh
    Jul 23, 2001
    752
    San Diego, CA
    on second thought, Id leave the rear drive shaft attached, jack up the rear wheels, and then do it. that way you could hold the brakes. other wise the only way to stop it is to throw it in park and if you have to give it throttle, it would start spinning real fast and possibly wreak havoc.
    what with the power of a v8, the torque multiplication of the torque converter, and low range on top of that, I bet you could easily apply several thousand foot pounds of torque, no?
    btw I dont usually do stuff like this /forums/images/icons/smile.gif Ive done the breaker bar on the harmonic balancer bolt a time or two but Im real cautious about it. if you think it thru, it can work really well and be safe.
    If my IR2131 couldnt remove the nut (that thing is pretty powerful) then Id get a cheater pipe on my breaker bar.. if that still didnt do it, then something is wrong. the nut is crossthreaded or welded on or something. Thats when you have to break out the big guns /forums/images/icons/smile.gif what ever it takes!!
    mike
  9. chevyfumes
    Feb 24, 2000
    38,584
    266
    I had to drop the case and put it on the bench, put the yoke in the vise and it popped out the first time and there was so much friction on the yoke from the vice it started smokin' /forums/images/icons/shocked.gif The second try it twisted the head right off of my 3/4" to 1/2" extension and the third time I put one foot on it and climbed on fer dear life, just as I was about to give in that sucker started moving. Just an incredibly nasty little bugger, by far the worst I've ever come acrosss..... /forums/images/icons/blush.gif /forums/images/icons/wink.gif
