front zero-rates, rub?
Discussion in 'The Garage' started by muddybuddy, Jul 17, 2005.
  1. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    hey guys, im beginning to think about getting some zero-rates to add to the 8" lift i already have, and moving the front forward 1". my question is by moving the axle forward, will the front rub on turns or in flex? im also thinking about getting one for the rear, but just as another inch of lift to even it out, cuz in my mind i think it would look weird w/o cutting the fenders.
    does anybody have pictures of their trucks with zero-rates, i want to see how the front looks with it moved forward before i set anything in stone.
    thanks, all help is much appreciated
  2. muddybuddy
    Jan 29, 2004
    8,933
    Fairfax Station VA
    anybody?
  3. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    moving the aqxle forward helps to decrease rub, because as the axle flexes, it moves backward.
    i moved mine forward 1 1/2" and it helped alot, no rub at all with 35's and a 6" lift.
  4. muddybuddy
    Jan 29, 2004
    8,933
    Fairfax Station VA
    ya thats what i thought. but under normal driving conditions on the road it doesnt hit the front?
    do you have any pics? i would like to see how the tire is in the fender
  5. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    well my fenders are all cut up now, but the lift tire combo i had diddent rub at all before i cut it
  6. 79k20350
    79k20350 3/4 ton status
    Nov 22, 2004
    7,757
    Ct
    If you cut the front fender under the marker light, you cant even tell the axle was moved. If you dont cut that tab of fender you may see it a little, but shouldnt be too noticable.
  7. muddybuddy
    Jan 29, 2004
    8,933
    Fairfax Station VA
    and the tire looked some-what centered in the fender? it didnt look funny?
    thanks for your responses.
