frontend shakes like a mofo!!!!!!!!!!!!!!!!!!help
Discussion in 'The Garage' started by ilikeitloud, Mar 7, 2004.
  1. ilikeitloud
    ilikeitloud 1/2 ton status
    Oct 30, 2003
    134
    edina, minnesota 55424
    hello, i just installed a GM 3/4ton 10bolt under the front and now at speeds above 30 the front end shakes like hell. i stuck my head out the window and notice my tires shaking left to right. and i also have a ton of play in the steering?whats goin on here? i have a 6in suspension lift with a new steering arm btw...
  2. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    you have the classic death wobble /forums/images/graemlins/eek.gif do a search on death wobble and you find out more info /forums/images/graemlins/thumb.gif
  3. mudjunkie 82
    mudjunkie 82 1 ton status GMOTM Winner
    Dec 27, 2002
    11,449
    Cleveland Ohio
    Check the frame where the Steering box bolts to and check for cracks, Also jack up the truck and check for bad tie rod ends or other Steering related parts.
  4. ilikeitloud
    Oct 30, 2003
    134
    checked the steering box thats fine.. but i took off the tire and the whole knuckle moves up and down 3/4 of an inch so im assuming time for new ball joints.
  5. mudjunkie 82
    Dec 27, 2002
    11,449
    Cleveland Ohio
    Yep, I would say so! /forums/images/graemlins/thumb.gifI would change all of them.
  6. 78GMC1/2TON4x4
    78GMC1/2TON4x4 1/2 ton status
    Mar 10, 2003
    167
    Mount.Angel, OR
    Or you might have to replace your wheel bearings and races.....mine was shaking like mad when i blew out bearings....above 25 MPH if recall...if thats the case, dont have to much fun /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif
