frount axle problems need help asap
Discussion in 'The Garage' started by 77ChevyK10, Aug 31, 2003.
  1. 77ChevyK10
    77ChevyK10 1/2 ton status
    Feb 2, 2003
    317
    Laveen, AZ
    The f#!ken drivers side axle shaft will not go back in. i have got the passenger side in no prob. so i pulled the damn spiders on the drivers side and slid the shaft in. Then put the spider on it and the spider will not go all the way back. It will not go together either way. someone please tell me what i am doing wrong.
  2. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    How far will it not go back together. Just not enough to get the hub snaprings back on? Or not even close to go back together? I have had axles not want to get far enough in to seat the snapring, but I just put a pry bar in the axle joint and pry inward until I get the clearence necessary.
    Harley
  3. 77ChevyK10
    Feb 2, 2003
    317
    Laveen, AZ
    still have an 1.5" to go inward.
  4. 77ChevyK10
    Feb 2, 2003
    317
    Laveen, AZ
    well i checked it and the tubs on the axle are bent so it is binding up. i do not have a clue on what to do to fix it.
  5. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
    What are the tubs? the ears where the ujoint is? I wouldn't know how to fix that except to replace them.
    I have some spare 10 bolt front axles. The inner won't be the same if you run a D44, but if the outer is bent a 10 bolt outer will work. If you need one let me know. I have 2 spare sets of front axles hanging around.
    Harley
  6. weisel
    weisel 1/2 ton status
    Feb 22, 2001
    491
    Laveen, AZ
    he meant "tube". The tube is bent on the drivers side.
  7. TrcksR4ME
    TrcksR4ME 1/2 ton status
    Feb 11, 2002
    2,482
    Seattle, WA 98103
    If the tube is bent, as in the housing itself, I think that the only way to fix it is to replace it /forums/images/graemlins/eek.gif
    These front ends are not to hard to find and do not cost an arm and leg though, so you should be able to find something pretty easy. I got my front end from another member here, it was just the housing and gears and then I swapped all my parts onto it. And if you do get a complete axle, you will have lots of spare parts /forums/images/graemlins/thumb.gif
  8. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    x
    x
  9. weisel
    Feb 22, 2001
    491
    Laveen, AZ
    Yes the side gear slides on real easy when not in the housing.
