frt 10blt tie rod on d44
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by down4thakrown, Jul 3, 2004.
  1. down4thakrown
    down4thakrown 1/2 ton status Premium Member GMOTM Winner
    Aug 5, 2003
    1,760
    75
    flagstaff,az
    would a 10blt front center tie rod work on a d44? /forums/images/graemlins/dunno.gif /forums/images/graemlins/thinking.gif
  2. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
    My 1990 1/2 ton 10 bolt tie-rod was a direct swap into my 1979 3/4 ton D44.
  3. jjlaughner
    jjlaughner 3/4 ton status
    Jan 12, 2001
    7,406
    Indiana
    going from the 10b to the D44 is just a matter of putting on top isn't it? /forums/images/graemlins/confused.gif
  4. heavy4x4
    Aug 28, 2002
    3,270
    Hmmm...actually (if I remember correctly), the tie-rod was underneath the knuckle on both axles. /forums/images/graemlins/thinking.gif
  5. thedrip
    thedrip 1/2 ton status
    Dec 13, 2003
    1,129
    Chattanooga, TN
    From what I've seen over about a half dozen d44 and 10bolt axles, is that flat top knuckle years had the tie-rod on top, and non-flattop years had the tie-rod below the knuckles.
  6. jjlaughner
    Jan 12, 2001
    7,406
    Indiana
    My 10bolts are on the bottom and the D44 I have is on top...
  7. heavy4x4
    Aug 28, 2002
    3,270
    I guess you just proved thedrip's theory...you, my friend, have flattops...I don't. /forums/images/graemlins/thumb.gif
  8. rcpilot
    rcpilot 1/2 ton status
    Feb 22, 2002
    507
    Central Cali
    Yesterday I put a '84 10B Center tie rod on '76 D44, I bouht new tie-rods ('84) for both sides, They both have bottom hung tierods... it is also an 1/8 larger in diameter /forums/images/graemlins/peace.gif
    BTW the draglinks also interchange (did that too)
  9. down4thakrown
    Aug 5, 2003
    1,760
    75
    flagstaff,az
    so it wont swap directly over?
  10. MTBLAZER89
    MTBLAZER89 3/4 ton status GMOTM Winner
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    Yes they should only difference being flattops mount from the top and all others are bottom mount. may have to adjust the length a bit but they should still fit.
  11. down4thakrown
    Aug 5, 2003
    1,760
    75
    flagstaff,az
    sweet thx
  12. ugly_blazer
    ugly_blazer 1/2 ton status
    Apr 12, 2004
    1,214
    I though that the top mount d44 tie rod ends are dropped down to clear the leaf spring, whereas bottom mount d44 and 10 bolts have straight tie rod ends /forums/images/graemlins/dunno.gif
  13. MTBLAZER89
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    Ahh yeah I forgot about that. I have 0-rates so I run regular TRE's on a top mount /forums/images/graemlins/waytogo.gif
