FS: 10b front axle 8-lug outer
Discussion in 'Suspension | Axle' started by blasphemous, Feb 14, 2007.
  1. blasphemous
    blasphemous 1/2 ton status
    Jan 11, 2007
    457
    Louisville, KY
    I have a 10b front that I was going to run, however I decided to go bigger and badder (picking up a D60 this weekend). I already converted it to 8-lug outers and has BRAND NEW Timken bearings and races in the hubs. The rotors have been replaced and are brand new. The old wheel studs were pressed back in, the threads are fine. The axle itself is 3.08 open, small bearing hubs/spindles.
    I have over $85 just in bearings and rotors. The hubs are for the large external lockouts. I have a set, but they're not in the greatest shape. Useable, just not very pretty... Warn hubs I believe, missing bolt to mount them to the hubs.
    It has the 3/4 ton backing plates on it, sanded and painted. I also have a set of calipers, but they're probably just cores. I haven't checked them at all. I'd like to get $250 for the entire axle, it's open to OBO though. May be open to trades for following items...
    -4' (or longer) pieces of 1.5" OD DOM tubing, .250" wall
    -4.56 14bFF gears (4.10 down carrier) or 4.56 gears AND carrier
    -2WD steering box
    -1-ton TRE reamer
    -NP205 SYE parts
    -Oldsmobile heads (big block)
    -BOP bell housing
    -1-ton U-bolts (longer than stock)
    -Saddle/transfer tank larger than 50 gallons
  2. bigjimmy82
    bigjimmy82 1/2 ton status Premium Member
    Dec 9, 2005
    362
    11
    New Albany, IN
    man if it was 4.10s
  3. blasphemous
    Jan 11, 2007
    457
    Louisville, KY
    Make me an offer, if you can find the gears, I know someone who will put them in and set them for $100.
  4. BizeeB65
    BizeeB65 1/2 ton status
    Oct 12, 2005
    859
    Louisville, KY
    i might be interested in the outers. you have everything to convert from 6 lug?
    Oh, and I still have that van if you're interested...:laugh:
  5. blasphemous
    Jan 11, 2007
    457
    Louisville, KY
    A buddy actually unloaded a car on me for the same price. Couldn't pass it up for a few reasons. Everything is there to convert from 6 to 8 lug. I just picked up a D60, so I'm not using it anymore.
  6. blasphemous
    Jan 11, 2007
    457
    Louisville, KY
    Outers/8 lug conversion parts for $200 OBO!
  7. fairlane_68
    fairlane_68 Registered Member
    Nov 22, 2002
    33
    Ft. Sill, Oklahoma
  8. blasphemous
    Jan 11, 2007
    457
    Louisville, KY
    bump, offers?!
  9. BizeeB65
    Oct 12, 2005
    859
    Louisville, KY
    my interest has been resparked... I am still working on that frame for you and will be in touch.
  10. blasphemous
    Jan 11, 2007
    457
    Louisville, KY
    You going to 3/4's? I've had a few "leads", but nothing's come through so far... locally.
  11. BizeeB65
    Oct 12, 2005
    859
    Louisville, KY
    yea, I got a lead on a CHEEP 14BFF... So if that comes through, I will be calling you.
  12. blasphemous
    Jan 11, 2007
    457
    Louisville, KY
    Alright, I'm going to get out to the garage in the next couple of days to check out that 12b too. Also, if you know anyone with a K-series truck frame too, I could use that also. Shortbed preferred, but I could cut down a longbed frame.
  13. blasphemous
    Jan 11, 2007
    457
    Louisville, KY
    TTT
    Make me an offer!
  14. broke73
    broke73 1/2 ton status
    Apr 12, 2005
    109
    Grand Blanc, MI
    PM sent
    PM sent.
  15. blasphemous
    Jan 11, 2007
    457
    Louisville, KY
    It was originally listed as 3.73, however it's a 3.08 open gearset.
