FS 2- Rockford Fosgate HX2 10" subs
Discussion in 'Audio' started by RingMaster4x4, Jan 1, 2002.
  1. RingMaster4x4
    RingMaster4x4 1/2 ton status Premium Member
    Mar 4, 2001
    2,049
    Bartlett, Texas
    FS 2- Rockford Fosgate HX2 10\" subs
    Size 10 inch
    Voice coil Configuration - Dual
    Material - Aluminum
    Description -
    3" 4-Layer
    Cone Material Paper
    Description - FIBERlock
    Frame Material Frame - Cast
    Material - Aluminum
    Surround Material Rubber
    Description -
    Santoprene BART
    Spider
    Crossover
    Specifications Power handling (RMS) - 500 Watts
    Power handling (Peak) - 1000 Watts
    Impedance - 4 Ohms
    Sensitivity - 85
    Vas (qFt) - .99
    Fs - 30
    Qts - .40
    Xmax (mm) - 13.97
    Dimensions Depth Bottom mount - 5.4375 in.
    Cutout - 9.3125 in.
    Displacement - 207.36 cu in.
    Enclosure Sealed box -
    Recommended volume (Cubic Feet) - 0.75
    Recommended volume (Liters) - 21.24
    Ported box -
    Recommended volume (Cubic Feet) - 1.00
    Recommended volume (Liters) - 28.32
    They are used and have a bandpass box to go with them if you want it. $200.00 + shipping. These are the only way to hear bass over a 427 with almost open headers.
    If you build it, the mud will fly!
    72 K5 blazer with a 427 tall deck and TH350/NP205 and 9"of lift with 40"tires.
