FS: Axle, driveshafts, 4" lift springs, speakers, Fluke meter
Discussion in 'General Parts for Sale' started by SCJimmy, Feb 11, 2004.
  1. SCJimmy
    SCJimmy 1/2 ton status
    Mar 7, 2003
    406
    Simpsonville, South Carolina
    FS: Axle, driveshafts, 4\" lift springs, speakers, Fluke meter
    10 bolt front axle from an '89 GMC Jimmy fullsize. 3.42 ratio
    Axle was rebuilt with new Moog tierod and draglink, new Perfect Circle ball joints, Warn premium hubs, brake rotors, pads, and calipers. It also has a 4" raised steering arm. I rebuilt the axle, and drove the truck for 2 months before the rear gov lock blew up. Truck sat for 3 months while I got a D60 and 14bff together for it. Axle was stored at a friend's garage (thought he was buying it) outside. Everything's in great shape, rotors need the rust knocked off of them, probably needs calipers again, since the ass-nut didn't plug them up when it went outside.
    $400 worth of new parts in it, gears and shafts good, will sell for $300 Prefer pick-up, willing to meet or deliver in SC-NC-GA areas.
    Rough Country 4" front lift springs. ran for 1 month, then went to Tuff country EZ rides with the new D60. Complete with like-new bushings installed. $100+ride
    1 pair of MTX Blue Thunder truck boxes. Three way, with a 10" bass driver in the front, mid and tweet in the top. Angles to fit behind truck seat. Work good, look their age, exterior banged up. $30+ride
    Front/rear drive shafts off of an '89 GMC Jimmy full size. (241 x-fer case)
    Decent shape and straight, slip-yoke rear had new joints before I went SYE. Good for trail spares or ??? $40/both+ride
    Pair of D60 spring plates. Went with TonyP angled plates and shims, don't need them. $45+ride
    Fluke 867B Graphical Multimeter Recent ni-cads, carry/storage case, charger. This meter is similar to the scope meter, but with limited scope functions. It does have different graphical trending, frequency, duty cycle, and logic functions. Case shows some wear, the meter works great. $580 ( Compare to new pricing )
    Set of stock F/R springs from '89. great shape, free to good home. You pick up.
    PM me for questions, pictures.
  2. Confedneck
    Confedneck 3/4 ton status
    Nov 1, 2002
    5,236
    Lehigh Acres, Florida
    Re: FS: Axle, driveshafts, 4\" lift springs, speakers, Fluke meter
    possible shipping on the lift springs to 33905??
    i have a feeling it wont be worth the cost..
  3. aztec777
    aztec777 1/2 ton status
    Aug 15, 2000
    316
    Reno, NV
    Is the front driveline for a 208/10 bolt? If it is will you sell it seperate? How much shipped to 89434? Thanks.
    Steve
  4. Confedneck
    Nov 1, 2002
    5,236
    ttt... answer on springs?
  5. SCJimmy
    Mar 7, 2003
    406
    PM sent to you, Confedneck...
    Aztec777, the shafts are from a 241 TC, don't know if it will work for you, yes, I will seperate.
  6. Dale fan
    Dale fan 1/2 ton status
    Dec 5, 2002
    167
    Arkansas
    I may be interested in that rear shaft if you want to split them up. I dropped you a PM.
