FS: well built '99 XJ, AL $8500
Discussion in 'Complete Vehicles' started by big94gmc, Mar 4, 2007.
  1. big94gmc
    big94gmc 1/2 ton status
    Sep 1, 2004
    No VA.
    1999 4door 4x4 5speed Sport
    Motor: 4.0L HighOutput
    -212,XXX miles
    -Airraid Throttle Body spacer
    -Bored Throttle Body
    -K&N cone filter with cleaning kit
    -Optima RedTop battery
    Transmission: AX15 5speed
    -B&M short throw sport shifter with Hurst T handle shift knob
    Transfer Case: NP231
    -Omix SlipYokeEliminator kit
    HP d44 front:
    -Yukon 4.88 gears
    -Yukon Carrier/Pinion bearings
    -Detroit EZlocker
    -Yukon 4340 inner/outter axle shafts
    -Yukon SuperJoints with full circle clips
    -New Brake Pads
    -New Calipers
    -New Brake Rotors
    -New inner/outer wheel bearings and hub seals
    -New wheel studs
    -New Lug nuts
    -New Warn Premium Hubs
    -Spare Passenger side inner/outer axle shaft with Spicer 760 Ujoint
    -Spare NEW MileMarker locking hubs
    -Skyjacker extended StainlessSteel brake lines
    -New Balljoints
    -New spindle bearings
    -New Inner Axle seals
    Ford 9in rear:
    -Yukon 4.86 gears
    -Detroit Locker
    -Yukon stock 31spline axle shafts
    -New Brake hardware (springs/clips)
    -New Brake shoes
    -New wheel cylinders
    -New wheel studs
    -New lug nuts
    Front Susp:
    -Rubicon Express axle bracket kit
    -Rubicon Express 7.5 springs
    -Rubicon Express Track bar
    -Rubicon Express Track bar bracket
    -Rubicon Express Track bar bracket brace
    -Rubicon Express Adjustable upper control arms
    -Custom lower long arms (2in 1/4wall DOM) with 2 ½ in Currie Johnny Joints with 1 ¼ cast shank on the frame side and RE superride bushings on the axle side
    -Rubicon Express 5piece Cross member/skidplate
    -Skyjacker 7064 shocks
    Rear Susp:
    -Rubicon Express 5.5in leaves
    -Rubicon Express Boomerang shackles
    -RoughCountry shocks
    -5 36x12.5x15 SuperSwamper TSL SX's very new, some rock rash
    -5 15x8 MickeyThompson Classic IIs also new but some rock rash
    Misc. Mods:
    -AGR SuperboxII steering box
    -Custom rear driveshaft by Huntsville Driveshaft
    -Alpine TypeR speakers
    -Delta h4 conversion headlights
    -Custom rocker gaurds and front tow hooks
    -Uniden CB radio with external speaker and shortie antenna
    -4in fog lights on front bumper
    This vehicle was purchased in 2000 and driven aprox 150miles a day on the interstate. Although high mileage, the motor is in great shape and has been closely maintained. It has a clean and clear title in hand. This Jeep has never been wrecked, although there is a small dent at the bottom of the drivers door and the rear passenger door, as well as scratches on the drivers rear door panel (see photos for all). The interior is in very good shape for mileage and age; never smoked in. The axle swap was professionally done in July 2006. It is still driven as a daily driver with no problems what so ever. This is a No Reserve auction!! The highest bidder will drive away in this XJ. The Jeep is located in Huntsville, AL 35803 (not Pensacola). Local pickup prefered, or, will ship at buyers expense, and buyer is responsible for total arrangements with shipper. No exceptions.
    Essentially, this is the ad I put up for my buddy in AL. Check it out.
  2. solidaxlesub
    solidaxlesub 1/2 ton status
    Feb 21, 2005
    tri-cities, wa
    nice jeep I saw it on pirate, too bad he dosent want a suburban:D
