fu#í up sound
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by **b**, Jul 18, 2000.
  1. **b**
    **b** 1/2 ton status
    279
    KIllington, VT.
    When ever i start off from a hill or have the
    wheels cut turning i give her a lot of gas
    she makes this almost binding noise .. it almost sounds as though the fan is rubbing its shroud no loss of power though
    any ideas????
  2. 6.2Blazer
    6.2Blazer 1/2 ton status
    Feb 24, 2000
    4,675
    26
    Ohio
    Check your front body mounts on either side of the radiator. My were destroyed and allowed the fan shroud to rub against the fan and cause a very loud rubbing sound when I went through ruts or flexed the suspension.
  3. Boss
    Boss 1/2 ton status Author
    2,550
    Maryland
    6.2 is right. Check your body mounts. It might be fine time to replace all of them. That happens to my truck too. I'm about to replace my body mounts with some Poly Engergy Suspension body mounts.
    Boss
