fuel cell pickup question
Discussion in 'The Garage' started by BigOrange90Jimmy, Apr 4, 2003.
  1. BigOrange90Jimmy
    BigOrange90Jimmy 1/2 ton status Premium Member
    May 24, 2002
    2,923
    Wilmington, NC
    I bought a fuel cell from MTPockets and I need to know how you guys would mount it. It's a 22 gallon RCI unit with the fuel lines at the bottom end of the tank. There's a lower area there so you can get all of the fuel out of it. My question is, how do I mount it so that on hill climbs I will not run out of fuel? It's a rectangular shape with the pickup on one of the short ends. Would I mount the pickup towards the cab, sideways towards the tires, or backwards?
  2. crwln73
    crwln73 1/2 ton status
    Sep 6, 2002
    362
    Clovis,Ca
    Is the low portion a sump?If it is is it baffled?
    Will it store fuel on an incline.
    I mounted mine with the sump towards the front,but mine is baffled to store about a gallon of fuel no matter what angle.Plus my return line feeds right on top of the sump,so as long as its runnin fuel is being pumped into the sump.I did starve for fuel one time while on a rock ledge on Sledgehammer.I was there quit awhile though.No problem though I just walked it forward with the starter till it leveled off and started.
