Fuel cell questions...
Discussion in 'The Garage' started by Confedneck79K30, Jan 23, 2007.
  1. Confedneck79K30
    Confedneck79K30 3/4 ton status
    Oct 1, 2006
    5,384
    LA
    guys with trucks, where'd you mount them, where'd you get them, how big, and what kind of fuel delivery do you use?
  2. 79k20350
    79k20350 3/4 ton status
    Nov 22, 2004
    7,757
    Ct
    I mounted 2, in the bed. I used an electric pump and used rubber fuel injection hose. They were 2 16 gallon tanks with ball vales mounted between them, also i used the feed and return lines on both
  3. FOR MUD
    FOR MUD 1/2 ton status Premium Member GMOTM Winner
    Apr 6, 2006
    2,801
    387
    Clayton Del
    When I did have one...In the bed...Jegs...20 gals...Electic fuel pump.
  4. twoslo4five0
    twoslo4five0 3/4 ton status Premium Member GMOTM Winner
    Oct 5, 2006
    6,614
    71
    Living in a dump, VA
    i got one mounted in the rear of my truck...its a 32 gallon..its huge but i got a deal on it at a race car flea mart...no foam though...i run an eletic ful pump with a regulator and a remote filter...setup works preety good...
  5. Confedneck79K30
    Oct 1, 2006
    5,384
    LA
    32 gallon is good, id prob go as big as i could get in mine.... i want to eliminate that damn rock slider fuel tank the factory put in for me...
  6. WRENCH-HEAD
    WRENCH-HEAD 1/2 ton status
    Dec 25, 2005
    327
    Littleton, CO
    I have run two setups. One was a custom fuel cell I had built, low profile under the toolbox. It worked great in the sand but the pickup placement didn't like off camber. I added a sump tank inline before the pump and the filter, but it would still starve after 5 min or so. Next is a 32 gal jaz cell that fits in the tool box. It is foam filled and has a sending unit to work with my guage. It has a smaller footprint so pickup placement is more effective. I will keep the sump tank for insurance though.
