Fuel Cell
Discussion in 'The Garage' started by drofdar, Jun 25, 2005.
  1. drofdar
    drofdar 1/2 ton status
    Dec 7, 2003
    113
    Fresno, CA
    My 1980 Fullsize has the dual saddle tanks. 22 gal ea, I think. I'd like to replace them with a cell under the bed where the spare used to be. Does anyone make a tank to fit this application? It would be great to get one with at least 30 gallons so I don't lose too much range. As long as I can still have good clearance, that is.
  2. LongIslander26
    LongIslander26 1/2 ton status
    Jun 25, 2005
    256
    Park County, Montana
    You can mount a suburban gas tank where the spare went, and they come in sizes of up to about 35 gallons. Some aftermarket companies make them to about 45 gallons. The good thing about this is you can buy stock gas lines for a suburban to replumb the system with, and it's all a direct bolt right in deal.
  3. drofdar
    Dec 7, 2003
    113
    Fresno, CA
    Fuel Tank
    That's great. I wonder if I can get a later model tank for fuel injection and have the in tank pump and return lines? I am going to switch to TBI on my new 383 build. Maybe GM would have the info on that.
  4. LongIslander26
    Jun 25, 2005
    256
    It should be a straight swap.
    it should be a straight swap, they used the same frame after they started using fuel injection.
