Fuel delivery issue
Discussion in 'The Garage' started by jk5blazer, Jan 26, 2006.
  1. jk5blazer
    jk5blazer 1/2 ton status
    Jan 28, 2005
    306
    Braselton, Ga
    Heres what I got: picked up an 89 TBI for 100.00 bucks from a friend, I want to run my truck avenger carb. Hopefully im retarded and its an easy fix, but what do I do about the fuel pump. The newer block doesnt have a place for the fuel pump to bolt up. Can I run a electric pump for a carb? If so does anyone make one for that applacation. Thanks for the help:confused:
  2. steve_kibbe
    steve_kibbe 1/2 ton status
    Feb 4, 2004
    2,895
    Spartanburg, SC
    Just use a pressure regulator.
  3. Chevy305
    Chevy305 6 Lug 14bsf Status Premium Member GMOTM Winner
    Jan 23, 2006
    11,228
    485
    New Hampshire
    Yes you can run an electric pump, just make sure you put in a pressure regulator. Carbs like it at about 5 - 7.5 and Holleys are a little sensitive when it comes to fuel pressure.
  4. jk5blazer
    Jan 28, 2005
    306
    Braselton, Ga
    i'll take that as a yes I can use an electric pump, an if so what pressure would be right. And any inline pump will do? Thanks
  5. jk5blazer
    Jan 28, 2005
    306
    Braselton, Ga
    thanks posted that after you answered that.:crazy:
  6. 1979jimmy350
    1979jimmy350 1/2 ton status
    Mar 24, 2004
    3,069
    Ann Arbor Mi
    being a 89 you should have just a block off plate where a fuel pump can go. I know they still had theses on a 93 1500 my dad had
  7. jk5blazer
    Jan 28, 2005
    306
    Braselton, Ga
    I'll check again, but there appears to only be a half milled out hole there. No spot for the fuel pump rod to go. but i'll check.
