Fuel Delivery or Spark problem? will BOP carb fit on my SBC?
Discussion in 'The Garage' started by Calclips, Oct 27, 2003.
  1. Calclips
    Calclips 1/2 ton status
    Apr 4, 2001
    1,005
    Swartz Creek, Michigan/Flint while in school
    I've got an 82 with an unknown quadrajet sitting on top of it. When you put it to the floor it will spit and sputter and almost stall out, but if you feather the throttle into the high rpms its fine. Plus, it seems to only really bog down while its in gear. I wanted to hit a bog on Sunday and don't really know a whole lot about the tuning of a SBC.
    How do I determine if its carb or igniton? I've adjusted the timing and can't seem to get the hesitation out.
  2. 99firehawk
    99firehawk 1/2 ton status
    Dec 15, 2002
    491
    Re: Fuel Delivery or Spark problem?
    How does it idle? I would be hooking up a fuel pressure guage and starting there.
  3. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
    Could possibly be a bad accelerator pump.
  4. Don
    Don 1/2 ton status
    May 30, 2002
    1,778
    Spokane Washington
    Secondary air door is opening too soon, causing over rich mixture, by pulling secondary needle's up. Pick up the book entitled "Rochester Carburetor's" by Doug Roe.
    Everything You need to know is in that book, from monojet's, to electric Q-jet's. It's a must have if you want to tune your Quad. /forums/images/graemlins/grin.gif
  5. Calclips
    Apr 4, 2001
    1,005
    Re: Fuel Delivery or Spark problem? will buick quadrajet fit chevy?
    So do could I adjust it extermally via the linkage?
    Also, I can get a free quad that was known to run good (my carb dosen't have that good of a reputation) my buddy will give it to me. Only deal is it came off a buick 350.... will it bolt?
  6. Emmettology 101
    May 9, 2000
    8,126
    FL
    As long as all the cable hook ups are the same, then that Q-jet from the Buick will bolt up fine.
