fuel delivery problems?
Discussion in 'The Garage' started by 1986chevy_rider, Feb 28, 2006.
  1. 1986chevy_rider
    1986chevy_rider Registered Member
    Nov 8, 2005
    97
    fallon nv
    I cant figure out why my carb is not getting any fuel in the bowls i just dont know ive changed the fuel pump. Ive hand pumped the pump just to see if the pump will pump and it did and it went into my fuel line to my carb. What could be wrong?
  2. trailblazr81
    trailblazr81 1/2 ton status
    May 27, 2005
    931
    Hollister, CA
    Check your filter. :dunno: Also when you hand pumped it was it hooked up to the gas tank or were you using some container of fuel? Could be sender in tank.
    Gremlins... Definatelly Gremlins!!!
  3. hack500
    hack500 1/2 ton status
    Sep 16, 2005
    523
    Templeton, Ma
    whatabout the filters? if the line before the pump has any leaks it may be sucking air not fuel. if the filters are clean and all the lines are good then the sock on the pickup in the tank may be clogged/collapsed.
  4. 1986chevy_rider
    Nov 8, 2005
    97
    fallon nv
  5. 1986chevy_rider
    Nov 8, 2005
    97
    fallon nv
    It was hooked up to the fuel tank not an external fuel tank. Is the push rod for the fuel pump sensitive or can they break or bend easily?I dont know
  6. trailblazr81
    May 27, 2005
    931
    Hollister, CA
    Its a pretty thick rod. Tho once you take off pump, should be able to pull it right out.
  7. 1986chevy_rider
    Nov 8, 2005
    97
    fallon nv
    So what do you think the problem is? Im stumped any sugestions.
  8. trailblazr81
    May 27, 2005
    931
    Hollister, CA
    If all your connections are good... check the pushrod in the engine. Would hate to think the fuel pump lobe on the cam wore down. Ive done it at the valve/lifter ends. That would have ment an oiling problem or a locked/frozen shaft on fuel pump.
  9. 1986chevy_rider
    Nov 8, 2005
    97
    fallon nv
    So should I look over all of my connections then take out the push rod and then maybe take one of those telescoping mirrors and try to look at the came lobe will that work or not. then if i did flatten my cam then should i put more money into the engine or rebuild my other block. and start all over? Or just pull out the rod and then put a block of plate on and then convert it to electric fuel pump and drive it till it dies. any suggestions
  10. sarasotausmc
    sarasotausmc 1/2 ton status GMOTM Winner
    Dec 16, 2003
    769
    Jacksonville NC
    After a week of kicking myself in the butt for about a week of having the same problem, I put gas in the tank. It fixed the problem. The pickup was "picking up" just enough to look like that wasn't the problem, so I looked everywhere else for a whole week. It was my last option before dropping the tank, but I guess I would've figured it out when I did.
  11. trailblazr81
    May 27, 2005
    931
    Hollister, CA
    Dumb-@ss!!! :doah:
    Just kidding. Good to know it was something simple and not sometihing in the motor. :woot: :saweet:
  12. 1986chevy_rider
    Nov 8, 2005
    97
    fallon nv
    So I went to replace the fuel pump with a carter electric and a pressure regulator and come to find out it was just the dang gas. but i guess you could say it was just the gas. thats all it was. dumb a#$
  13. sarasotausmc
    Dec 16, 2003
    769
    Jacksonville NC
    I called myself worse. I've had the truck dialed in for a while, so that certainly couldn't have been it. 1986, I know how you feel.
