fuel delivery question!
Discussion in 'The Garage' started by blackblazer717, Jul 1, 2004.
  1. blackblazer717
    blackblazer717 1/2 ton status
    Jul 1, 2004
    470
    massachusetts
    ok
    i have an 88 K-5 with a 350 and TBI, last week the motor quit, i found that the PCM-B fuse had blown which is the fuel management fuse. i have replaced the pump relay and the in-tank fuel pump as well as the fuel filter (cause i was under their) and the problem persists. you can put a new fuse in and the truck will run until you take it down the road and than the fuse will pop again. any help would be greatly appriciated
    also, is it possible to bypass all of the factory harness and hard wire the pump to a switch? and have the truck runand not just have the pump come on?
    thanks
    luke
  2. fortcollinsram
    fortcollinsram 1/2 ton status
    Nov 8, 2001
    2,261
    Fort Collins, CO
    YOu have a short somewhere...First, I would ensure you have a good ground at the fuel pump. Then start checking the wire from the FP to the FP relay. You can hardwire a 12v+ but I wouldn't reccommend it...Fix what you got /forums/images/graemlins/wink.gif
    Chris
  3. blackblazer717
    Jul 1, 2004
    470
    massachusetts
    i also traced the tan/wht wire from the FP to the relay, though the bulkhead connector and to the fuel pump oil press switch and everything is checkin out.
    also i tryed hard wireing the fuel pump and it will turn on with the switch but the truck wont fire, maybe somthing from the ECM is required???
