Fuel delivery question
Discussion in 'The Garage' started by tiger9297, Nov 6, 2004.
  1. tiger9297
    tiger9297 1/2 ton status
    Jul 23, 2004
    1,205
    Tupelo, Mississippi
    Have a 90' K-5, about to rebuild engine. Would like to get 400+ hp but want a good smooth running RELIABLE engine. Daily driver. Stock TBI is horrible as you know. I assume I can't go with a carb. b/c of the computer stuff. The multipoint systems are $2000+. I know I'm not the only one that has had this problem. Sucks that there really doesn't seem to be very many options out there. /forums/images/graemlins/angryfire.gif
  2. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    You can go carb. You just remove the TBI FI stuff (complete and sell it) and then add on a carb manifold, carb distributor, and carb.
    If you stay with the stock TBI fuel pump you can put a fuel pressure regulator on and the extra fuel will return to the tank.
    If you are building a motor then just make sure you get a set of carb (86 and earlier) heads so you can have a wide section of manifolds.
    I am a HUGE fan of multiport FI but if you can't afford it you can't afford it. I used to run a carb and I don't think I will ever run one on a offroad truck again after having a MPFI system.
    Harley
