Fuel delivery ?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Brady, Sep 22, 2000.
  1. Brady
    Brady 1/2 ton status
    May 6, 2000
    628
    Parachute,Co
    I am having problems with fuel delivery.When my rig sits overnight it won't start with out pouring gas in the carb.It also will not keep the filter full(clear filter).I just put a new pump on tonight and it did not help.I don't have any leaks fixed them already.Could it be the cam?Any ideas would help and be appreciated.Brady
  2. 6.2 man
    6.2 man 1/2 ton status Premium Member
    636
    Curtis , WA
    Sounds like a carb problem ( if you have a carb )Sounds like it's leaking fuel into the engine .Does your oil smell gassy ??
  3. mudfanatic
    mudfanatic 1/2 ton status
    Feb 18, 2000
    614
    Aloha, Oregon
    I have this same problem, my fuel line goes dry, not overnight but over the course of 3-4 days I will have to prime the fuel pump by dribbling fuel down the line and fill it from the pump to the top then attach it to the carb.
    My oil has never smelled gassy, I was wondering if the needle and seat on the float has a good seat, would that cause this problem???
    Dan
    <font color=red>get involved with land issues or lose the land</font color=red>
  4. fr8train
    fr8train 1/2 ton status
    Aug 2, 2000
    1,712
    Maryland
    It kinda sounds like a leak from one of your fuel lines. I would think its like a siphon, when you let air in it loses "suction" letting liquid back into the tank. Have you checked all the fittings? How about pinhole leaks in the line? Also is the gas cap sealing? Loss of vacum and pressure here could be a little bugger. Just a thought.
  5. mudfanatic
    Feb 18, 2000
    614
    Aloha, Oregon
    on older models like mine it really doesn't matter about the gas cap because there is a breather vent on top of the tank that allows atmospheric pressure to stabilize inside the tank. On your diesel and fuel injected vehicles there is a sealed system with a return line, this is when the cap is critical.
    Dan
  6. Brady
    May 6, 2000
    628
    Parachute,Co
    I think I found the problem.Way up on top of the fuel tank there is a little leak in the feed line.Too bad the parts store and truevalue are closed already!I'll have to fix it tomorrow and see if that is it.Probally rebuild carb again also.Brady P.s. anyone with ford shock mounts see my post called ford shock mount ?thanks!!
    '73Beautiful Disaster
