fuel filler neck
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by gravdigr, May 16, 2003.
  1. gravdigr
    gravdigr 1/2 ton status
    Apr 15, 2003
    1,129
    Tyrone, PA
    Anyone have any idea where I can find one of these for a 79 K5? I have tried LMC, classic industries and a few other different places and nothing. LMC does have one listed for 81 and up blazers but would this work on my 79? When I got this rig it had no gas tank or the filler neck and hose.
  2. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    jc whitney should have them
  3. 79Jimmy
    79Jimmy 1/2 ton status
    May 10, 2000
    214
    Richmond BC, Canada
    Got mine at the dealership /forums/images/graemlins/smile.gif IIRC the only difference between the years is the tube diameter at the hose end. The 79 one necks down whereas the later ones dont. I got one for my 79 before I got a newer 91 tank which meant the diameters were different. This is where the luck comes in. I needed a new rubber line to conect the two anyways so I was racking my brain looking for some sort of reducer or adapter solution. I looked at it one more time and though "That filler neck, before the neckdown, looks pretty close to the diameter of the tanks tube. Sure enough it was pretty close. A quick trip down to the local marine hardware store for some 2" fuel hose, a few inches longer than stock, and some new hose clamps and I was in business /forums/images/graemlins/smile.gif Long story short, a 79 filler neck can be made to work all the way up to 91 /forums/images/graemlins/cool.gif
    James
  4. gravdigr
    Apr 15, 2003
    1,129
    Tyrone, PA
    I got a new fuel tank and it is for a 79 so it would prolly have the narrow neck. I guess I could try a 81+ filler neck and try to reduce it if I can't get a 79 one. I jus checked JC whitney no go there.
