Fuel filter/carb gasket(Quadjet)
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by BowtieBlazer, Jan 8, 2002.
  1. BowtieBlazer
    BowtieBlazer 1/2 ton status
    Jul 15, 2001
    2,462
    Baton Rouge, Louisiana
    Does anyone know where I can find the right gasket for the fuel filter shroud on my qudjet carb. The guys always point me towards the help section but the ones that are supposed to fit, don't. I noticed that every now and then a drop of gas drips from that shroud onto the intake because i do not have the proper gasket. What do you do? If you have a part number or ideas I'd apprciate it.
    Granny LOW and let her GO!!
    1985 GMC C-10 Shortbed
    1984 Chevy K-5 Blazer
  2. xnoahx
    xnoahx 1/2 ton status
    Oct 12, 2000
    817
    Ventura, CA 93004
    what type of gasket are you talking about? Dont the peices just screw into the carb? Have you tried using some teflon pipe tape to seal the threads?
    My 73 K5 <a target="_blank" href=http://www.geocities.com/xk5blazerx/73k5.htm>http://www.geocities.com/xk5blazerx/73k5.htm</a> 350/TH350/NP203, Q-jet, Edelbrock intake, Vortec heads, 4" lift, and 36" TSL's
  3. Chevit
    Chevit 1/2 ton status
    Dec 10, 2001
    1,492
    dnaltroP, nogerO
    That's what I did.....
    84 K5, Crate 350, 700r tranny, 3.73 rear, 32 11.50 15, Q-jet
  4. BowtieBlazer
    Jul 15, 2001
    2,462
    If I remember right gasoline will eat teflon tape in no time. The peices do indeed screw into the carb but if I remember right when i first bought the truck there was very thin flat o-ring type gasket there. (This gasket would be between the "filter cup" and the carb not the gas line and the cup) I just dont know that i'll feel safe knowing my baby could go up in flames from a missing gasket and gas hitting a hot intake....guess i'll give teflon tape a try for now...
  5. ironmikek5
    ironmikek5 1/2 ton status
    May 31, 2001
    145
    Massachusetts
    I've never used a gasket, and didn't see any when removing the quads from my Blazer &amp; Jimmy.
    I got some "fuel system sealer" tape from Autozone for a couple of bucks, it has never leaked a drop.
    <font color=red>I will not tolerate intolerance </font color=red>[​IMG]
  6. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    i used teflon tape. no problems here.
    -zakk
    '77 1-Ton K5
    World's Ugliest Lawn Ornament
    [​IMG] CK5's Moab 2002 or Bust!! [​IMG]
