Fuel Filter Location
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Confederate9, Sep 25, 2000.
  1. Confederate9
    Confederate9 1/2 ton status
    May 29, 2000
    1,686
    Greensboro NC
    ok i need a new fluel filter, but i have no clue where to locate mine. i have a stock 305 in my 85 k5 sliverado edition
    can someone tell me where its at? thanks guys
    Confederate's w/ K5's!
    '85 K5: BIG BAD AND MEAN
    "DONT BE PROUD IF IT AINT LOUD!"
  2. ken
    ken 1/2 ton status
    1,244
    Anaheim, CA
    Well, if its in the same location as Suburbans, it'll be on your inner right side frame rail, about under the passenger side door. Good luck!
    ken
  3. 82K5
    82K5 1/2 ton status
    191
    kansas city
    and if it's not there. try looking in the carb where the fuel line goes into it.
    phil
  4. Dieselmh
    Dieselmh 1/2 ton status
    910
    Texas
    Also try looking on the inner frame rail of the driver's side, that's where my truck's is located. Stick your head under the door and look back towards the outside of your blazer, it should be tucked inside the frame rail.
    Diesel
    If it ain't broke, fix it 'til it is.[​IMG]
  5. Mr Red
    Mr Red 1/2 ton status
    263
    Washington, DC Metro Area
    If you have the stock Q-Jet, it should be in the carb. My '86 is like this. If your facing the front of the rig, the front left corner of the carb is probably where the fuel line goes into the carb. You'll see two nuts there for removing the filter that inserts into the carb slightly. But, this varies depending on Qjet. Like mentioned before, follow the fuel line. I'd say yours is closer to the carb than the posts about frame rail mounts. That's usually in a FI system.
    Good Luck,
    <font color=red>David, '86 K5</font color=red>
  6. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    I'm pretty sure its ony in the framerails if its a TBI
    90K5
  7. scavenger
    scavenger 1/2 ton status
    Mar 31, 2000
    111
    Southern Wisconsin
    I also have an 85 K5 Silverado with the 305 motor with the Quadrajet Carb and the fuel filter is located where another member stated it would be....as you are llooking at your motor standing in front of it the fuel filter is at the front left side. You will see where the metal fuel line goes into the carb. If I remember correctly it will take the long paper filter. I don't recall 85's having fuel injection.
