Fuel Filter Problem . .
Discussion in 'The Garage' started by larryslamps, Nov 30, 2006.
  1. larryslamps
    larryslamps Registered Member
    Nov 10, 2006
    17
    Kentucky
    87 k5 TBI Never changed its fuel filter before, its tucked in the passenger
    framerail, I can't seem to bust the nuts loose. Any suggestions? I don't want to bend or break my fuel lines.
  2. 4xcrazy
    4xcrazy 3/4 ton status
    Oct 31, 2003
    9,472
    5
    Olympia/Lacey, Washington
    Two wrenches, opposite directions :p: :D
    they will break loose,,,oh, and have some rags handy, the filter is below fuel tank level, get ready to unscrew the filter fast once it's broke loose, and slap on the new filter real quick,,,you're GONNA spill some fuel :D
  3. larryslamps
    Nov 10, 2006
    17
    Kentucky
    I don't mean to seem ignorant I just want to do it right, one wrench on each side of the filter ( not the nuts on the filter ) right?
  4. 4xcrazy
    Oct 31, 2003
    9,472
    5
    should have a place for the wrench ON the filter, and the line, use a wrench to basically hold the filter, and loosen the line nut,,,on both sides...
    DO NOT completely remove the line nuts until you are absolutely ready to swap out the filter, just break them loose first, like i said, fuel will keep coming out while the filter is removed. Kinda need to be quick about it :D
  5. dyeager535
    26,982
    191
    I wouldn't even TRY this without a tubing wrench. You round the nut flats off the fuel line, have fun. Cost you a bunch more than a tubing wrench to fix.
  6. randy88k5
    randy88k5 1/2 ton status
    Nov 8, 2004
    1,248
    Lynchburg, VA, USA
  7. sweetk30
    Nov 1, 2004
    25,552
    546
    horseheads , ny 14845
    line nuts in good shape are 16mm . and filter end is some odd ball. i just use a big adjustable wrench for more leverage to hold it. if you can take 2 hammers and place one behind filter at the nut to filter location. then on other side tap the nut / filter area with other hammer . this will help loosen up the rust. but be vary easy to not flaten or damage stuff.
