Fuel Filter Replacement on TBI?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Overdrive, Sep 30, 2001.
  1. Overdrive
    Overdrive Registered Member
    Feb 28, 2000
    93
    Gilbert, Arizona
    OK, I received some great tips on how to clean up my TBI throttle body now just one more question. How do I depressurize the fuel injection system on my 89' so I can replace the fuel filter (I know the filter rides inside the frame rail). Thanks for any info
    Overdrive
  2. KENT
    KENT 1/2 ton status
    139
    Roseburg, OR
    I just had a cup ready to catch the fuel as it comes out of the line. It was no worse that changing a filter on a non FI rig. Let the rig set for a few hours or overnight it should let most of the preasure off just sitting.
    Be sure to keep some rags handy and wear safety glasses!
    Also a fire extingisher.
    Kent
    1989 K5
  3. Itali83
    Itali83 1/2 ton status
    Feb 12, 2001
    795
    Westbrook Maine
    The system depressurizes after a little while so no big deal, but it does make a mess and loose quite a bit of fuel, I've learned this the hard way.
    Ben 87 Jimmy
    <font color=blue>Rust=Bad</font color=blue>
    <a target="_blank" href=http://www.bens87toy.alloffroad.com>www.bens87toy.alloffroad.com</a>
  4. chevrules
    chevrules 1/2 ton status
    Aug 26, 2001
    127
    Canada
    no big deal,let the truck sit for a few hours and then crack the line loose...you will get gas coming out so cover eyes and maybe put a drain bucket on the ground.
    chevrules...always has and always will
  5. Overdrive
    Feb 28, 2000
    93
    Gilbert, Arizona
    Hey, Thanks a lot guys I will give it a try.
  6. Bubba Ray Boudreaux
    Bubba Ray Boudreaux 1 ton status
    Jan 21, 2001
    20,716
    Undisclosed Location
    Or take the ecm fuse out and crank a couple of times. This will let out the pressure also.
    Bubba Ray Boudreaux,
    "Tell them the U.S. is coming, and hell is riding with us!!"<a target="_blank" href=http://community.webshots.com/user/mdntrdr1>http://community.webshots.com/user/mdntrdr1</a>
