#$$%#$!@#$ Fuel Filter, ????'s Now What?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 1990SilveradoK5, Jul 5, 2001.
  1. 1990SilveradoK5
    1990SilveradoK5 1/2 ton status
    Jan 2, 2001
    185
    Napoleon, OH
    #$$%#$!@#$ Fuel Filter, ????\'s Now What?
    OK, after my truck started to Stu..Stu..Studder I decided to replace the fuel filter. Picked one up today but now I can not get the (*&$_(@^$_(*$ old one off the truck.
    Front braided hose is off but back solid line won't budge. Tried to use my &)(*&)( tiawan made flair nut wrench and snapped it in too. Now I have the )(*$@#*&)(*^ flair nut rounded off. _)(*$)&$_)*(#@&%_*(#@&%_(*&$_*(&@#*(&$&
    What pressure does this run at?? I have plenty of hose laying around that will handle pressure and fuel. Any suggestions???
    Can I just cut the line and splice in a section of hose??
    Need suggestions tonight if possible, as she's setting in the driveway.
    And I thought this one was a simple swap. *&)_*(&%@_(#%&_(*&%
    Gone Large and Loving It.
    Keith
  2. Flipper
    Flipper Registered Member
    Oct 19, 2000
    38
    West of Mpls. MN
    Re: #$$%#$!@#$ Fuel Filter, ????\'s Now What?
    Been there, soak with penetrating oil, use piece of steel behind flats on tubing and slap opposite flat with hammer.
    Shock will break rust loose.
    Flip
  3. 1990SilveradoK5
    Jan 2, 2001
    185
    Napoleon, OH
    Guess I just needed to bitch alittle, went back outside and took some big @ss vise grips and got her loose.
    Only &%_(*&%_@ problem now is the swivel on the line infront of the filter is leaking like a stuck pig. I guess another trip to the autoparts store is in order.
    Just needed to vent as this week has been one PITA after another.
    Keith
  4. K5Jimmy
    K5Jimmy 1/2 ton status
    Sep 21, 2000
    1,141
    Lake Dardanelle/Logan Co, Ark
    I thought bitchin' was part of the fun....gives ya a reason to wear knuckle bandages.......not to be splel checkin', but I don't think #$$%#$!@#$ has the "!" before the @....I think it's after the third "#" and between the "$$".....I may be rwong.....
    Stuck?...Hell no..I still got some gas left..
  5. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    The<font color=red> ***####!!!!</font color=red> fuel pressure should be 9- 13 <font color=red>**""''::##</font color=red> PSI
    GOOD LUCK !!!!!!!!!!!!!! Keep smiling.
    <font color=orange>GOT HORSEPOWER?</font color=orange><P ID="edit"><FONT SIZE=-1>Edited by Thunder on 07/05/01 10:44 PM (server time).</FONT></P>
