fuel filter
Discussion in 'The Garage' started by sunnyc123abc, Aug 23, 2005.
  1. sunnyc123abc
    sunnyc123abc 1/2 ton status
    Mar 12, 2005
    636
    SoCal
    how often are u suppose to change it, and where is it located on an 84 blazer with a 305, thanks.
  2. jekquistk5
    jekquistk5 Weld nekid Premium Member GMOTM Winner
    Jan 18, 2004
    11,005
    836
    Pinckney, MI
    I changed mine every 50k, and pass side frame rail, I believe
  3. sunnyc123abc
    Mar 12, 2005
    636
    SoCal
  4. jekquistk5
    Jan 18, 2004
    11,005
    836
    Pinckney, MI
    yeah and make sure you use two wrenches to take it off so you do not cross thread the fitting. And a few rags as well, gas is never fun to get all over you
  5. 4X4HIGH
    Dec 14, 2001
    22,059
    69
    Pleasanton, CA.
    I'm pretty sure that the only fuel filter factory on that year is in the fuel fitting at the carb where the fuel line attaches. Someone may have installed and after market inline fuel filter anywhere though.
    Later years with TBI had a fuel filter on the passenger side frame rail.
  6. sunnyc123abc
    Mar 12, 2005
    636
    SoCal
    how do i bled it, am i just suppose to start it right up
  7. jekquistk5
    Jan 18, 2004
    11,005
    836
    Pinckney, MI
    doh my bad I need to go to bed i read 84 at 89
  8. 4X4HIGH
    Dec 14, 2001
    22,059
    69
    Pleasanton, CA.
    As long as it's gas then just crank til it starts. :thumb:
  9. sunnyc123abc
    Mar 12, 2005
    636
    SoCal
    coool...thanks man big help, even for little things. im going to get a full membership next week.
  10. dyeager535
    26,975
    Make sure to use a tubing/flare wrench when you go to take the fuel line off the carb, and make sure that the line isn't sticking to the fitting as you try to unscrew it. It will save you hassle to get everything apart without damaging things. As you can imagine, it's a pretty common problem trying to remove that steel fuel line after all these years.
