fuel filter
Discussion in 'The Garage' started by smking77, Mar 8, 2007.
  1. smking77
    smking77 Registered Member
    Mar 8, 2007
    6
    arizona
    i just got a 82 chevy blazer and i found a switch connected to the fuel filter. is it suppose to be there??
  2. smking77
    Mar 8, 2007
    6
    arizona
    some 1 please help
  3. Dudge
    Dudge 1/2 ton status
    Sep 9, 2006
    351
    Kentucky
    The fuel filter? Are you sure it's not a fuel pump? I know ppl sometimes ditch the manual pumps in favor of an electric pump, and they sometimes run them by a switch. Does it have wires going to it and the switch mounted in the cab? Or does it have an actual switch on the body?
  4. smking77
    Mar 8, 2007
    6
    arizona
    i looked it up on the net and it said fuel filter. the filter is mounted under the truck and there is a switch in the truck that i followed and it led to the filter. when i turn the switch on the filter makes a buzzing sound
  5. Elevator Man
    Elevator Man 1/2 ton status
    Dec 23, 2005
    240
    Bigelow, Arkansas
    Its an inline pump! will the truck run with it turned off?
  6. smking77
    Mar 8, 2007
    6
    arizona
    yea the truck runs with it off. i just want to know if i need to turn it on or how its suppose to work
  7. dyeager535
    26,979
    It's not factory, so no telling why its there.
    Probably installed to replace the stock mechanical fuel pump and they couldn't get it to work right.
  8. stoney126
    stoney126 1/2 ton status
    Jun 2, 2005
    1,458
    napa,CA
    there a company name on it? any model numbers perhaps?
  9. Jason4x4
    Jason4x4 1/2 ton status
    Nov 5, 2006
    4,505
    6
    Chandler, AZ
    I would imagine someone probably had some vapor locking issues so they added a booster pump.
  10. TexasBlazerBoy
    TexasBlazerBoy 1/2 ton status
    Oct 10, 2005
    1,674
    North Texas
    With the switch set to the off position, could it be a theft deterent device?
    No fuel no start? or am I way off
  11. smking77
    Mar 8, 2007
    6
    arizona
    the maker of the part is napa auto parts and the model # is 3033. if i leave the switch on the filter stays on and u can hear it buzzing. so if im driving do i need it on?
  12. BKinzey
    BKinzey 1/2 ton status
    Jan 13, 2006
    3,145
    Hollywierd, CA
    The buzzing most likely just means it's running. As mentioned the PO probably put it on there. Why? Who knows?:confused:
  13. smking77
    Mar 8, 2007
    6
    arizona
    when i get in the truck should i turn it on or should i just leave it off
  14. gmc4cw
    gmc4cw 1/2 ton status GMOTM Winner
    Jul 19, 2006
    3,907
    west chester, Pa
    when I went to Napa's site the part number you listed is a basic inline fuel filter. no wires. My geuss is that you have a electric fuel pump mounted somewhere very close to this filter. see how long the truck will run with the switch turned off. if the tank has gas and the truck shuts off after a few minutes then you have an electric pump controlled by the switch. Or take a picture and post it so we can see what you are talking about.
  15. Leper
    Leper 1/2 ton status
    Feb 18, 2005
    4,437
    Dallas Baby!!!!
    He can't post pics. Not a member.
