Fuel Gage Acting Wierd
Discussion in 'The Garage' started by ron_mac01, Oct 27, 2005.
  1. ron_mac01
    ron_mac01 Registered Member
    Sep 26, 2005
    17
    ATL,GA
    I JUST RE-INSTALLED MY FUEL TANK AND EVERYTHING WENT WELL. GETTING TO THE POINT I PUT A FULL TANK IN AND IT WENT PASS THE (F) AND IVE BEEN DRIVING FAR AND THE GAGE WONT COME DOWN BELOW (.25 FULL) ANYBODY HAVE ANY SUGGESTIONS???????????????????? :confused: :confused: :confused: :confused:
  2. shaun89
    shaun89 1/2 ton status
    Aug 7, 2005
    1,942
    center of CT..ish
    this might be a dumb suggestion but maybe the float is stuck in the tank?, or any links attached to that might be stuck :doah:
  3. diesel4me
    Jul 24, 2003
    17,552
    939
    Massachussetts
    ground!
    Make sure the ground wire is,good, connected, and the rust is scraped off where it bolts to the body..if its not that,then it must be the sending unit is bad,or the float might be stuck,like Shaun said.. :crazy:
  4. prossett
    prossett 1/2 ton status
    Sep 29, 2005
    165
    United Arab Emirates
    Someone on the forum told me to spike the ground to the chassis and not the tank, and it worked for me.
  5. Greg72
    Mar 5, 2001
    15,683
    1,392
    642 Days to BB2018
    TAKE OFF YOUR CAPS LOCK????
  6. PsychoticDeadGuy
    PsychoticDeadGuy 1/2 ton status
    Jan 8, 2005
    753
    Fairfield, California
    so the ground for the fuel guage is all the way at the tank? could i cut it and put the ground somewhere else? my guage does the same thing. would it affect any other guages? my oil pressure guage has been stuck in the same place since i got the truck.
  7. prossett
    Sep 29, 2005
    165
    I don't think it's the ground from the gauge (why not ground it somewhere closer) so I think it runs from the sending unit. I've never taken one apart so I can't say for sure.
    What I've got is a wire that runs from somewhere on top of the fuel tank to a screw on the outside of the tank, on the front left side, up high. It's clearly a ground wire.
  8. Robert D
    Robert D 1/2 ton status
    Oct 2, 2005
    261
    Austin, TX
    What are your thoughts regarding my fuel gauge issue...91 GMC Jimmy...the fuel gauge goes to half full when I fill up the tank and goes down from there. It seems to work, however, when at empty I fill up ~25gallons to top it off. I haven't looked up the specs on the size of the tank, but isn't it what 30-35 gallons?
  9. anjieandjohn
    anjieandjohn Registered Member
    Oct 31, 2004
    61
    Virginia Beach
    I have the same problem...I think my sending unit is bad though. I will redo the wire connections when I replace it. For now, I just fill up at 200 miles regardless so I know I wont run out of gas....not that I havent figured out that I needed to do that the hard way!! Psycho, I had the same problem recently with my oil pressure guage and replace my sensor. As I replaced the sensor, I found the wire was broken and causeing it to indicate peggerd to the right.
  10. terrier72
    terrier72 1/2 ton status
    Jul 6, 2004
    201
    Greenville, SC
    I just had the same problem when reinstalling my tank, i checked everything or so i thought. I forgot about the most obvious thing, the fuse. I replaced it and now it works fine.
  11. dyeager535
    26,979
    Ground the sending unit gauge wire back at the tank connector and see if your gauge pegs. If it does, it's not the gauge. If it doesn't, the problem is forward of that connector.
  12. Robert D
    Oct 2, 2005
    261
    Austin, TX
    Also, it appears the clear plastic cover over the guages appears foggy, as the PO applied a corrosive cleaner to it at some point. Can the clear lenses be purchased new, aside from buying a complete guage assembly?
  13. mimosaid
    mimosaid Newbie
    Mar 2, 2005
    egypt
    It might be a bad shunt resistor that is installed at the back of the gauge.
