fuel gauge/ low idle stall
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by MA87K5, May 27, 2000.
  1. MA87K5
    MA87K5 1/2 ton status
    Apr 6, 2000
    558
    Chicopee, Ma 01020
    Hey everyone. Well the first problem I have is that my fuel gauge moves while the K5 is standing still. What could cause this? I have tried fixing it by tinkering with the sending unit but no change. The second problem is that it will stall or get real close to stalling when the idle gets low or even while I am driving slow like around 5-20 mph. I have 87 K5, 350 TBI, 700r4. Please help. Thank you
  2. coopertwpk
    coopertwpk 1/2 ton status
    Mar 18, 2000
    478
    Spring Valley Lake Ca.
    idle contol solnoid (left side round with four plug connection)remove it and spray carb cleaner in the hole it may be plugged it should vibrate when you turn ont the key it controls air flow to keep the idle steady.
  3. dumbfounded
    dumbfounded 1/2 ton status
    May 20, 2000
    176
    Castalia, NC
    check your air cleaner and throw in some carb/efi cleaner in the gas (can't hurt its cheap), as for the gauge check connections. Does it do it with the key on and engine off?
    Blood, sweat, tears, and lots of money is what keeps my K5 alive.
  4. jarheadk5
    jarheadk5 1/2 ton status
    Mar 6, 2000
    4,389
    PA
    Replace the fuel filter as well. Inside the right framerail under the pass. door. 10 minute job.
    Silly question, but does the gauge move after stopping, or when the truck has been still for a while? I'm thinking the gauge may be dying, or the circuit may have a poor ground somewhere. Or, the baffles in the tank aren't doing their job.
    [​IMG] Semper Maintenance!
  5. MA87K5
    Apr 6, 2000
    558
    Chicopee, Ma 01020
    The fuel filter is new about 4 weeks ago. The gauge moves when truck is still and moving also with the key on and engine off, but I worked on it on Saturday and so far it is fixed. I'll try to spray the silonoid with cleaner. Thanks
  6. Blazer79
    Blazer79 1/2 ton status
    1,816
    Guatemala, Central America
    Mine did the same thing. I followed the wire that comes from the tank. I found it was broken and someone had just twisted up the two broken ends and were all dirty. Definitely a bad contact. I cut them off and redid the union. Problem solved.
    <font color=black>//////
    What the heck!...Drive it like gas is $0.50/gal!!!
    </font color=black>[​IMG]
  7. Whii338
    Whii338 Registered Member
    Apr 24, 2000
    35
    Mine did the exact same thing...low speed stalling but ran ok at speed....88'K5 350 Tbi auto.. and the egr valve was bad...stuck, whatever ,no emissions inspection in alabama so its just unhooked and runs fine but i am going to replace it soon(it may make your check engine light come on..but mine was bad and didnt come on:) run great now...just my 2cents.
  8. MA87K5
    Apr 6, 2000
    558
    Chicopee, Ma 01020
    The guage worked fine before I messed with the fuel pump. New the sending unit cost around $300 from dealer. Parts stores dosen't sell them. I used a meter on the sending unit while out and there was a fluctuation in thr ohm reading, unknown if it was ok. The next time I'll try reading it while the unit is in the tank. I shall check my egr valve. Thanks everyone for your help.
