fuel gauge not working!
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Marshall, May 3, 2003.
  1. Marshall
    Marshall 1/2 ton status
    Apr 8, 2002
    204
    LiveRmore,CA
    MY fuel guage om my truck stopped working all of the sudden i dont know what the problem is i checked all connections and fuses. does anyone know what might be causing this problem if so please let me know.It is a 31 gallon tank and the vehicle is an 87 Jimmy
    Thanks, Marshall
  2. JustHorsinArownd
    JustHorsinArownd Registered Member
    Mar 20, 2003
    77
    Flagstaff, Az.
    I'm thinkin the sender.
  3. Grim-Reaper
    7,385
    Atlanta
    Check the wires the whole length. I had a Tree rat or a chipmunk chew up some wires on my truck and got the gage wire. They also got the return fuel line. /forums/images/graemlins/shocked.gif
  4. santana
    santana 1/2 ton status
    Jan 11, 2003
    1,483
    Mesa Arizona
    I had that same problem. Does it stop at about half way? If it does regardless of amount of gas, Theres a pan inside the tank that came loose causing the sender to jam up against the said pan. Just a possibility but like posted before me, Id check the wiring first before dropping the tank especially if its full.. /forums/images/graemlins/thumb.gif
