fuel gauge problem
Discussion in 'The Garage' started by SF87K5, Mar 3, 2004.
  1. SF87K5
    SF87K5 1/2 ton status
    Oct 27, 2002
    1,105
    Stedman, North Carolina
    I filled up my truck sunday and put 29 gal. in it. My fuel gauge would not go past 3/8 of a tank. I have a 90 350TBI and the tank that was with it. I was told if it did that it was the sending unit. Well today when I was driving home it started to bounce all over. Know it is pas the full mark, its as far right as it can go and does not move when I turn my k5 off or turn it on.
    Could this be the sending unit or the fuel gauge that is f**ked up?
    Yes the instament cluster is out of the 90 along with all of its wiring. Also the gauge worked fine before last sunday.
  2. cuzinjay
    cuzinjay Registered Member
    Feb 13, 2004
    62
    rome ny
    Check the wires the tank they get coroaded (can'spell that one) or a broke wire will peg the gauge.
  3. rooferbret
    rooferbret 1/2 ton status
    Dec 26, 2003
    265
    Sacramento,CA
    You might want to check the baffle in the tank as it my have come loose. My gas gauge never worked right till I installed a new fuel pump and found the baffle loose. Works great now.
  4. CaveBlazin
    CaveBlazin 1/2 ton status Premium Member
    May 21, 2002
    1,348
    Middle TN
    Actually mine does this all the time I just give the fuel gage a smackin, just beat it!!!! If when smacking it directly does'nt work then smack the top of the dash right above it that usually works for me.. LOL Come on danny I know you remember how to get military equipment working think of this as the same. /forums/images/graemlins/woot.gif
  5. SF87K5
    Oct 27, 2002
    1,105
    Ok I have check the wires and all the conection and everything is good. Oh and yes Spence I bet the piss out of it like you do a Hummer still nothing. I guess after we move I will drop the tank and check the baffle and I will unhook the gauge and test it with my buddies new one he has.
    Thanks for all the help.
  6. bablazer73
    bablazer73 1/2 ton status
    Apr 4, 2000
    3,363
    upstate ny
    My wifes 87 had the sending unit fall off. She ran out of gas. The gauge still read 1/2 tank. At first i thought the fuel pump went, so i dropped the tank. Felt kinda light!!
  7. conoverbandit
    conoverbandit 1/2 ton status
    Jan 23, 2002
    452
    Conover N.C
    SF87K5,
    I got the tank still under that k-5 frame that I got from Big orange. He said it had good set up in the tank. If ya need it buddy............................
