Fuel gauge question...even after reading hundreds of search post.
Discussion in 'The Garage' started by jakeslim, Apr 30, 2003.
  1. jakeslim
    jakeslim 1/2 ton status
    Sep 18, 2002
    2,686
    Napa, CA
    If my fuel tank is empty, and my fuel gauge is pointing to the half way mark, what is the problem?
    1--sender wire
    2--sender unit
    3--gauge
    4--ground for sender unit
    6--the float is not working properly?
    Someone please clarify this. I really read through many, many post via "the search" but am still unclear.
  2. jakeslim
    Sep 18, 2002
    2,686
    Napa, CA
    ttt....anyone? I know I can't be the only one with this problem. It's a 77 k5.
  3. Don
    Don 1/2 ton status
    May 30, 2002
    1,778
    Spokane Washington
    Fuel tank sending unit, is t.u. purchase a new one. /forums/images/graemlins/eek.gif
  4. chevyfumes
    chevyfumes Court jester
    Feb 24, 2000
    38,584
    266
    Watch for the muzzleflash!
    Check the ground, some others have had the same prob and that was it, mine does the same thing also.... /forums/images/graemlins/eek.gif /forums/images/graemlins/thumb.gif
  5. jakeslim
    Sep 18, 2002
    2,686
    Napa, CA
    well, i'll see if i can mess with the ground tomorrow(its supposed to rain in this damn state). It seems there would be a definite solution to a problem that plagues many of us.
  6. dyeager535
    26,982
    191
    No ground it should go overfull as I recall, so unbolting the ground and turning the key on should force the gauge to move.
    If the gauge actually moves until it hits the halfway point, it's either the gauge or the sender more than likely though. But it never (ever!) hurts to check/clean grounds.
  7. chevyfumes
    Feb 24, 2000
    38,584
    266
    [/ QUOTE ] Thats what I got outta his prob [ QUOTE ]
    [/ QUOTE ] /forums/images/graemlins/eek.gifjust that it would be over what it actually said.... /forums/images/graemlins/1zhelp.gif
  8. dyeager535
    26,982
    191
    Official GM "fuel gauge short test"
    Basically, it says disconnect the pink wire, and turn the key to "run". If it reads "full" then replace the gauge (allow 1 minute for the change in reading). If it still indicates empty check/repair pink wire for short to ground, cluster printed circuit, and gauge connections. Replace fuel gauge if pink wires, printed circuit, and gauge connections are good.
    Another test is to take the pink and ground it, then connect it to the ground wire. Both should send the gauge to "E". If fuel gage indicates correctly both times, repair/replace sender. If pink to ground test fails (doesn't read E), check pink wire, printed circuit, and gauge connections. If those are fine, replace gauge. If Pink to ground wire test fails, check/repair the black ground wire.
    The sender test is more complex, as the tester varies the resistance between 0 and 90 ohms which is empty and full, respectively. Basically, if that works the gage correctly, that means the sender is bad.
    You could do this yourself if you pull the sender from the tank (if you are pretty sure thats the problem after other testing). Measure resistance between the pink wire and the ground wire. Move the float arm from bottom to top (empty to full) Empty should be 0, full 90, and everything in between should be fairly close (IE approx halfway is 45, etc). Can't move the float very fast though, have to let it "settle" to get a good measurement.
